Factory Limited Slip
Hello, I just bought a 2005 SS/SC, and wanted to know if it had a LSD, so I went the industrial park and found out that I have (2) marks. However, on the option code sticker in the trunk, I see no G85 option. Did they offer the LSD under another option code, or do I have an aftermarket LSD, or just an f'ed up open?
Easy way to tell...Do you have Recaros?
Yes > You have LSD (unless someone swapped the seats)
No > You don't have LSD (unless someone switched the seats)
Plus I believe it says LSD on the tranny somewhere
Ok I just went and looked...On the drivers side by the fuse box. If you look straight down on the tranny there is a black metal tag with a bar code (you may have to move a few wires to see it) it has a GM symbol on the bottom left corner (if your standing on the drivers side of the car looking towards the passenger side) and on the top left hand corner it will say LSD and then some numbers. If the tag doesn't have LSD on it than you have an open diff...
Last edited by Tazmanian_Dvl; Aug 9, 2008 at 12:02 AM. Reason: Automerged Doublepost
Iceberg
Sep 29, 2015 12:33 PM
z28addiction
Sep 28, 2015 12:03 AM
