FINALLY an option for us f35 guys. READ!
Old 06-08-2011, 05:55 AM
  #251
Powell Race Parts's Avatar
Emco USA have produced close ratio 3/4/5 gear sets for the M35. 1000 bux each set... just fyi....
Old 06-08-2011, 07:11 AM
  #252
terry11's Avatar
I have never heard of them. Is anyone on this site running them or have they been tested for higher horsepower application? F35 you mean?
Old 06-08-2011, 07:38 AM
  #253
jb09ss's Avatar
Straight cut gears?
Old 06-08-2011, 08:43 AM
  #254
Tennpenn83's Avatar
Originally Posted by MTE
All you guys are just dreaming too high, 7500 rpms!! lol, you shouldn't be putting so much attention at your tranny but to your engine internals, what good is a tranny that can go that high if the engine wont tolerate it? You will also need 500 whp to benefit from 7500 rpms on an aluminum block 4 banger engine, then you'll have to worried about your sleeves taking a ****. Not to mention replacing your seals every 2 months.
Anyways, you know I'm just talking **** right? jaja
I would assume that most people that would drop this kind of money on a tranny have also dropped the money to rev it out..
Old 06-08-2011, 09:50 AM
  #255
cmiller8006's Avatar
Heres the thing, people with stock turbos do not need a built tranny. I ran a full drags set up twice a week for two years on the stock tranny. Close to 50 1.7 60 foots on it as well. Why make a tranny that is going to be a stock replacement, there are alot of people going to bigger turbos nowadays. All you need for 7500rpms is valvesprings, nothing else. There is nothing to worry about with sleeves either, Also changing the ratios will only mean about a 5 mile per hour change from 7000 to 7500. The stock tranny gear ratios suck period. If there is a guy making new gears but only doing 3 and 4 why not take advantage of this and get the ratios where they should be?
Old 06-08-2011, 09:52 AM
  #256
Thanks for the info.
Old 06-08-2011, 10:02 AM
  #257
FF_ace's Avatar
truth. hows the car by the way?
Old 06-08-2011, 10:08 AM
  #258
Doing ok, you? This turbo likes to be boosted lol. Going to put in race gas and goto 30psi today I think.
Old 06-08-2011, 10:30 AM
  #259
BYT*SS*TURBO's Avatar
Old 06-08-2011, 11:12 AM
  #260
FF_ace's Avatar
Nice I'm going to fix my lines then see what it can do with a e85 mix
Old 06-08-2011, 02:05 PM
  #261
Baron7700's Avatar
random, but I want to go to whatever dyno you did for those numbers (lol). I have considerably less whp/wtrq on my dyno and i ran better times than your 1/4 on street tires.
Old 06-08-2011, 02:24 PM
  #262
Rattlesnake Race Shop
USMCFieldMP's Avatar
Also if he is remaking 3 and 4 is there a way he could decrease the ratio? Like getting third to end at about 100 if your revving to 7500? and then make fourth at one to one? Not sure if all that means a whole bunch more work or since he is already making new gears if it wont be to bad.
I would prefer my gear ratios to be left stock.
Why don't you get a 4.45 ratio gear set... sounds like that'd be more along your lines.
Old 06-08-2011, 02:42 PM
  #263
the 4.45 is more of a band aid for the shitty gearing. What we would be doing is making more along the lines of the srt gearing. Also why would you like stock gearing? If your going to say because of highway pulls, if you think about it you will accelerate faster with the gearing I said. Get into fourth sooner which being 1:1 will make for a monster. We would have to talk with shep to find out the rpm drop between gears to make sure we wouldn't drop out of the turbos efficiency range to keep the pull hard and smooth. I hate getting into third at 75 and being in it all the way to 130 mph lol. Through a 26 inch tire on it Nd it's now like 140, which is gay lol.
Old 06-08-2011, 04:00 PM
  #264
Our gearing has always worked out really well for me. 4th gear is already a monster for me.
You have to remember... I have a 4.05 final, so mine aren't quite as long as yours.
Old 06-08-2011, 04:07 PM
  #265
HHRSSouth's Avatar
Exactly why I have wondered why more Cobalt SS/TC owners haven't swapped out there 3.82 final drive trans for the HHR SS 4.05 final drive trans.
Old 06-08-2011, 04:30 PM
  #266
John Powell has stated that the case on the lnf is stronger than the lsj. That is one reason, I wouldn't mind the 4.05 as long as the diff is LSD and is as strong as the lnf one. The lnf diff is quafe or how ever it's spelled. Bit I deffinitly don't want the 4.45.
Old 06-08-2011, 04:33 PM
  #267
Even though it seems stout in 4th you are losing power do to it being an overdrive gear. I lost 6 whp on the dyno on the stock turbo from 3rd to 4th.
Old 06-08-2011, 04:36 PM
  #268
And I am not trying to persuade anyone either, I truely believe this would make for a better overall car.
Old 06-08-2011, 04:40 PM
  #269
HHRSSouth's Avatar
The HHR SS uses the LNF case with a 4.05 final drive. I have quaife (or however you spell it) LSD also and Brembos.
^^^^I'm really surprised this option hasn't been explored by Cobalt SS/TC owners already.
Old 06-08-2011, 04:43 PM
  #270
See I didn't know that. Good info. What does thrid do at 7000rpms?
Old 06-08-2011, 05:55 PM
  #271
HHRSSouth's Avatar
Off the top of my head I have no idea, but I do shift at 7k rpms 2-4th gears.
My 4th gear pulls almost as hard as my 3rd gear.
Next time i take the HHR SS out I'll let you know, I actually did WOT 2-4 gear pulls today shifting at 7k for a datalog for Vince to fine tune the E35 blend in, but I didn t look at MPH. I just watched the redline between shifts.
Old 06-08-2011, 06:56 PM
  #272
Yea I would like to know, this might be something I would want to do when I do a tranny.
Old 06-08-2011, 09:38 PM
  #273
i like the 4.45 a lot.i run it.
i like the idea of a six speed
i like the idea of a cr 3/4/5.
i make my gear charts in excel
Old 06-08-2011, 10:18 PM
  #274
terry11's Avatar
Thanks for this! Really good to know. I might do the 4.45 if John frowns upon the ratio change
What size tire is this on?
Old 06-08-2011, 10:44 PM
  #275
I would imagine the stock size. But that is a 4.05 ratio which looks like a nice option really.
Quick Reply: FINALLY an option for us f35 guys. READ!
