Fluid for the SS/SC Tranny
Old Mar 15, 2007 | 10:16 PM
05OrangeSS's Avatar
As the title states, Im trying to figure out what fluid goes in this tranny. I've checked the owners manual, and it states 1.8quarts of AUTOMATIC TRANNY FLUID?! That doesn't seem right to me, but I've seen somewhere that it takes some specific GM Manual tranny fluid. If anyone could actually tell me what the hell to put in the damn thing I would appreciate it.
Old Mar 15, 2007 | 10:21 PM
jeremie's Avatar
we use saturn fluid. go to a saturn dealership and get saturn manual trans fluid.
Old Mar 15, 2007 | 10:24 PM
tremorz's Avatar
when is tranny fluid to be changed?
Old Mar 15, 2007 | 10:27 PM
05OrangeSS's Avatar
Im putting a new clutch in......which requires a drain and refill......
Old Mar 15, 2007 | 10:32 PM
jeremie's Avatar
a clutch doesnt require a drain and fill.. i've done 2 in the past week and i didnt drain them. i only had to add a little due to fluid coming out when i pulled the axles. you shouldnt need to drain all the fluid though
Old Mar 15, 2007 | 10:40 PM
05OrangeSS's Avatar
Might as well though right?? Plus Im not doing it, my buddy is, and he's never done a cobalt clutch.....although many different hondas,evos and such
Old Mar 15, 2007 | 10:42 PM
jeremie's Avatar
ahh. tell him not to remove the 7mm bolts that hold the fuse block together. if you need info on how to do it pm me, i have access to GM service information
Old Mar 15, 2007 | 10:43 PM
avro206's Avatar
surprised no one mentioned this.....
auto trans fluid is used in most manual transmssions these days. Not sure why but GM thinks its good. Stick with it. You can go Mobil1 ATF is you wish.
Old Mar 15, 2007 | 10:47 PM
Red2.4SS's Avatar
Yep the manual transmissions all call for ATF! I just put Mobil 1 synthetic ATF in mine yesterday!
Old Mar 15, 2007 | 10:53 PM
tremorz's Avatar
i meant, in general, when is best to change a tranny fluid?
Old Mar 15, 2007 | 10:56 PM
jeremie's Avatar
actually, gm calls for 21018899 for the trans in an ss/sc, which is a gear lube from saturn, not atf.
Old Mar 15, 2007 | 10:59 PM
StinkBOMB's Avatar
When I had my SS S/C it definitely did not call for ATF. Intense sells what you need. Or if you happen to feel motivated, use the search button and you'll find out it's just fully synthetic 90W gear oil. You can try ordering the correct lube from your stealership, but expect it to take quite some time if they don't have it in stock. I gave up after 2 weeks of waiting.
Yep, Intense sells this fluid.
Old Mar 15, 2007 | 11:07 PM
05redline's Avatar
Any GM dealership should be able to get it.
Old Mar 15, 2007 | 11:34 PM
jeremie's Avatar
i know. but it says saturn in big red letters on it which is why i call it saturn fluid. and you'd have better luck getting it at a saturn dealership considering every time i need it we have to go pick some up
Old Mar 16, 2007 | 10:29 AM
blktrax's Avatar
This is straight fom GM powertrains.
http://media.gm.com/us/powertrain/en...EC20LI4ENGINES
Type: transverse front wheel drive, five-speed manual transaxle ( optional with limited slip differential )
Engine range: 2.0L I-4 supercharged
Maximum engine torque: 200 lb-ft ( 271 Nm)
Maximum gearbox torque: 258 lb-ft ( 350 Nm )
Gear ratios: MU3
First: 3.38
Second: 1.76
Third: 1.18
Fourth: 0.89
Fifth: 0.7
Reverse: 3.17
Final Drive Ratio: 4.04
Maximum validated gross vehicle weight 2300 kg
Case material: aluminum
Center distance: 76.5mm
Fluid type: Castrol BOT 0063 - I've only seen this at GM dealers
Transmission weight: wet: 45 kg ( 99 lb )
Fluid capacity (approximate): 1.7L / 2.0 qt. ( dry )
Power take off: no
Applications: Chevrolet Cobalt
Saturn ION
2007 Getrag F23 ( M86/MG3 ) 04/04/06
Engine range: 2.2L - 2.4L DOHC (M86/MG3)
Maximum engine torque: 155 lb-ft ( 210 Nm)
Maximum gearbox torque: 170 lb-ft ( 230 Nm )
Gear ratios: M86 MG3
First: 3.58 3.58
Second: 2.02 2.02
Third: 1.35 1.35
Fourth: 0.98 0.98
Fifth: 0.69 0.81
Reverse: 3.31 3.31
Final Drive Ratio: (M86) 3.84( Cobalt, ION ), 4.17( HHR )
Final Drive Ratio: (MG3) 4.41( VUE )
Maximum validated gross vehicle weight: M86: 4094 lb ( 1857 kg ) MG3: 4475 lb ( 2030 kg )
Center distance: 75 mm
Fluid type: DEXTRON III
Transmission weight: 46.3 kg ( 102 lb )
Fluid capacity (approximate): M86: 1.7L / 1.8 qt ( dry ) MG3: 1.8L / 1.9 qt ( dry )
Power take off: no
Applications: Chevrolet Cobalt ( M86 )
Pontiac Pursuit ( M86 )
Saturn ION ( M86 )
Chevrolet HHR ( M86 )
Saturn VUE ( MG3 )
2007 Hydra-Matic 4T45 Transaxle( MN5 ) 40406
Type: four speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch
Engine range: 2.2L - 3.5L
Maximum engine torque: 205 lb-ft (278 Nm)
Maximum gearbox torque: 325 lb-ft (440 Nm)
Gear ratios:
First: 2.95
Second: 1.62
Third: 1.00
Fourth: 0.68
Reverse: 2.14
Final Drive Ratio: 3.05, 3.29
Maximum shift speed: 5800 rpm
Maximum validated gross vehicle weight: 1990 kg (4347 lb)
7-position quadrant: P, R, N, OD, 3, 2, 1
5-position quadrant: P, R, N, D, D3 (Malibu)
Case material: die cast aluminum
Shift pattern: (2) two-way on/off solenoids
Shift quality: variable bleed solenoid
Torque converter clutch: pulse width modulated solenoid control
Converter size: 245mm (reference) (diameter of torque converter turbine)
Fluid type: DEXRONŽ VI
Transmission weight: dry: 74.7 kg (164 lb)
wet: 85.1 kg (187.6 lb)
Fluid capacity (approximate): bottom pan removal: 7L (7.4 qt)
Complete overhaul: 10L (10.6 qt)
dry: 12.5L (13.2 qt)
Pressure taps available: line pressure
Transfer design: two-axis design, link chain assembly
Assembly sites: Windsor, Ontario
Chevrolet HHR
Pontiac Pursuit
Chevrolet Malibu
Chevrolet Malibu Maxx
Pontiac G6
Saturn ION
Saturn AURA
Saturn VUE
Old Mar 16, 2007 | 10:42 AM
CTCOBALTSSS's Avatar
Castrol BOT 0063?? Interesting. Well now that we are up to say 4 different types of tranny fluid, which is the correct one??
Old Mar 16, 2007 | 10:54 AM
BlueSS-supercharged's Avatar
syncromesh is what i heard
blktrax's Avatar
Castrol makes it for GM and is redistrubuted by GM, im looking for the GM part number..
Yup
for SS/SC
Lubricant GM P/N 21018899
2.0 quarts
for LS/LT
Manual Transmission Fluid GM P/N 88861800 (Canadian P/N 88861801)
1.9 Quarts
AutomaticTransmission Fluid Type
DEXRONŽVI
Transmission Fluid Capacity - Approximate
Bottom Pan Removal: (7.0 qts)
Old Mar 16, 2007 | 10:57 AM
StinkBOMB's Avatar
There you go. That should do it. At least when I took my owners manual to my local stealership that's the stuff I had them order.
Old Mar 16, 2007 | 11:06 AM
Ok there is the part number, missed it.
So I imagine Crate Engine Depot would have this. I shall see.
Just go here and type in the part number. It's $7.38
http://gmpartsdirect.com/ 21018899
Old Mar 17, 2007 | 03:33 PM
05OrangeSS's Avatar
Word, just picked some of that fluid up......for the low low cost of $27
Old Mar 18, 2007 | 03:44 PM
TxLonghorn#1's Avatar
Has any body thought about using Royal Purple Synthetic ATF fluid? Would this work for our cars(ss/sc)?
Old Mar 28, 2007 | 01:24 AM
nybull05's Avatar
That was going to be my question cause that is what i want to put in mine. I saw on here somewhere were someone did use royal purple in there car. I just want to make sure before i shell out the money for it.
Old Mar 28, 2007 | 02:34 AM
HunterKiller89's Avatar
im assuming mobil 1 ATF is safe for the auto trans....and id imagine safer than for a manual for obvious reasons
is it okay to mix transmission fluid types? i just bought my transmission cooler and will need to top off the tranny fluid when its installed....n i dont know if i should just replace it all or just top it off
Old Mar 29, 2007 | 10:34 PM
Johnboy12358's Avatar
I am very interested in this as well...
My gut reaction is no, dont do it.
DarrenGC
Dec 24, 2021 01:55 PM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
