Flywheel
It is a great idea to switch to a lightweight flywheel, the car's rpms will rev higher and drop faster, your car will feel completely different, it would also be a good idea to do a clutch while your down there too, i had a fidanza flywheel on my car it made a worl of differnce, try using the search button also, as there is many posts on this.
no. because you are not getting a "lightweight" flywheel. that is what yeilds the quicker revs. machining the stock flywheel is appropriate when you replace the clutch and do not want to purchase a new flywheel.
ok hopefully someone can answer this for me because i keep trying to figure it out and am trying to learn...
when installing a light flywheel Why is it important to install a better clutch at the same time?????
please someone give an informative answer to this.... i know im not the only person wondering....
If you change the flywheel to a lighter one, you will be altering the mass elastic system of the crank. The damper on the crank is tuned based on the flywheel inertia, crank inertia, cyliner pressures, etc. By altering the mass elastic system and the damper being tuned to the inappropriate frequency, the amplitudes of the crank's torsional vibrations will increase and potentially cause fatigue and failure to the crank and the mains. If you want to change the flywheel, you should have the system retuned and get a new damper, which is not very easy and will be very expensive...just my $0.02 (I design torsional dampers for cranks).
The engine will rev much faster with the aluminum flywheel, offering better throttle responce and more power.
We have one (1) 2.0L Fidanza flywheel for only $289.99 + ship (email or PM us for the discount code) We again will only offer this price for one unit.
Much faster rev, smother eceleration, and power gain in all rpm's. Only down side is 1st gear. Its bad enough as it is and now its that much worse but you make up for it in 2nd and 3rd. Trust me.lol
EXIGED,
the reason you would need a better clutch is for more clamping force....since the revs will be quicker, you need to "grab" the flywheel with more pressure. the factory pressure plate isnt worth having off the showroom, much less with mods. hope this helps ya.
thanks for the quality info everyone!
but does anybody know if the L61 (i believe thats what its called.... the 2.2l) is internally or externally balanced, where that would be a concern?
