View Poll Results: Which ratio should I choose?
Keep the stock 4.05 ratio
9.76%
3.82 ratio
22
53.66%
4.45 ratio
36.59%
Voters: 41. You may not vote on this poll
Gear Ratio Poll
Old 09-27-2008, 11:40 AM
BlackSS/SC's Avatar
It's not goint to be a cheap or easy job that just anyone can do. You have to have the special tranny tools and tear the whole think apart to do it. Just as bad a putting a LSD in a non-LSD tranny.
Old 09-27-2008, 11:56 AM
spike's Avatar
i have a shop 2 do my stuff they r the one that r cryoing my trans but i just need 2 locate the 3.82 FDG stuff.....
IMO the 3.82 would e crazy for the turbo guys cause the SS\tc is faster that the ss\sc and it cant rev as high... So with a 400whp car reving 2 7500+ plus the 3.82 gearing it would be crazy...And i do agree that the 4.45 gearing would accel faster but at those power levels unless u r on drag slicks u will just spin tire in about every gear. Also the 3.82 would be great for reducing torque just enough 2 hopefully help wear & tear....imo
Old 09-27-2008, 12:02 PM
BlackSS/SC's Avatar
That's right, that is why I'm having such a hard time desiding.
Old 09-27-2008, 12:05 PM
Killa SS's Avatar
This is why i need this. and better fuel economy
Old 09-27-2008, 01:16 PM
BlackSS/SC's Avatar
Remember I'm on drag slicks too.
Old 09-27-2008, 02:07 PM
spike's Avatar
Yeh I just want 2 auto-x.... But I think in ur case the 4.45 gears would b 2 low. U would have 2 launch in 2nd and shift a ton of times before u got 2 the end of the track...srry 4 the text typing(phone post)
Old 09-27-2008, 02:12 PM
BlackSS/SC's Avatar
No problem man lol
I was thinking the the 4.45s leaving the line in 2nd gear but I think it would bog a little too much. The would use 2 3 4 in the 1/4 mile.
The 3.82 I'll use 1 2 3 and 3rd will be good up to 120ish mph.
Old 09-27-2008, 02:22 PM
qwikredline's Avatar
your kidding right? for autox its a no brainer: 4.45
No problem man lol
may go to the strip tomorrow i will let u know if i do....hoosier slicks for sure like why bother with street tires?
Old 09-27-2008, 02:25 PM
BlackSS/SC's Avatar
Let me know for sure!
I agree, the 4.45s for auto-x would be the best hands down.
I'm thinking 3.82 again now for drag racing because everything I've read on other forums and books. Turbos like taller gears and will keep me in load easier and longer.
I feel like a YOYO!!!
Old 09-27-2008, 02:53 PM
Deathscythe's Avatar
the tvs guys need some love too!
Old 09-27-2008, 03:06 PM
  #36
spike's Avatar
Well I want the 3.82 for a daily mpg\ roll racing...also at the power I will b at 4.45 is way 2 short...imo...4.45 would just b bad for cars over 300whp.
Old 09-27-2008, 05:51 PM
  #37
want love get meth
Old 09-27-2008, 05:56 PM
  #38
brandon2.2's Avatar
I would say to go with the 4.45 for dragging, i never heard that turbos like tall gears, you're reving to over 7 grand and are turboed, I would without a doubt go with 4.45
I say this because I think you would want lower gears to help keep your car in its power band. With the info that rally gave you, look at that, and if you're worried about shifting, just practice and get faster at it or something.
Old 09-27-2008, 06:04 PM
  #39
want love get meth
I have the stage 2 kit from ais, it just needs to be installed. I know that cooling is of the utmost importance with the tvs.
Old 09-27-2008, 06:07 PM
  #40
Killa SS's Avatar
so how could i buy these parts brand new and what would i need? as far as parts go
Old 09-27-2008, 06:59 PM
  #41
so install it = get love oh and you HAVE to tune for it
Old 09-28-2008, 01:14 AM
  #42
ralliartist's Avatar
if you get the 3.82, you will without a doubt, be slower. No way around it. The 3.82 will only increase your gas mileage. That will be your only positive from that. If you get the 4.45, you'll not only be faster, but your top end won't suffer to badly as the jump from 4.05 to 4.45 isn't enough to destroy your topend.
Old 09-28-2008, 12:32 PM
  #43
BlackSS/SC's Avatar
I hope that's the case and I won't lose so much shifting since I'm turbo. Most of the research I did on other turbo cars showed they switched to taller gearing with a turbo too because they like more load and it helps spool and keep spool going.
It just seems that as it is I'd benifit from the taller gears and the shorter would kill me because of the extra shift.
I used this calculator http://dirtjapan.com/myscript/gear_selecter.php
I typed in gear ratios from other cars and they all seemed to be taller then ours when taking the individual 1st, 2nd, 3rd, 4th & 5th ratios into consideration. Check it out.
It's the 1st to 2nd shift that kills me because of the split in gear ratios. The RPMs drop down too low and I lose boost. The I gotta wait for it to go again. I was hoping with the 3.82s the wheel speed would be higher and help the turbo recover quicker.
Old 09-28-2008, 07:34 PM
  #44
pay attention to ralli, and now my input its all about the hook you gotta hook up and i am not sure you are, if you are and the car falls down, then retune....thats my opinion 4.45 is faster....
Old 09-29-2008, 10:47 AM
  #45
BlackSS/SC's Avatar
Well I decided to go with the 4.45s....
Old 09-29-2008, 11:00 AM
  #46
cruisn's Avatar
good choice you wont regret it
Old 09-29-2008, 11:06 AM
  #47
BlackSS/SC's Avatar
I sure hope so lol
1st gear will suck but the rest will be much better.
Old 09-29-2008, 08:45 PM
  #48
you need to work on that launch. Play with different pressure in your slicks and be sure to get them heated up properly. You shouldn't be spinning 10.5" mickey thompson slicks that easily.
Sl0wbaltSS
11-21-2018 11:11 PM
RaginChopsuey
10-27-2015 01:27 PM
biniecki
10-25-2015 02:23 PM
DocSvensk
09-27-2015 02:24 PM
brett.higgins3
09-24-2015 09:51 AM
Quick Reply: Gear Ratio Poll
