GMPP Clutch Bite Point Question
so complicated. pump the pedal moderately slowly two or three times, hold down. open and close bleed screw. repeat once. done. drive.
the initial bite will be low. this will change after a couple of days. If you want to change it right away, just load the car up a bit with a second gear start. Once.
burnished. done.
burnished. done.
burnished. done.
burnished. done.
u are a good driver and dont slip clutch, it will last a long time. as it wears it will come off the floor. at the end the engagement will be very high lol
When i replaced my gmp clutch with a new one just for the heck of it, i was pleased to find that i had hardly worn down the original gmpp with 20+k miles on and a good amount of racing. Flywheel was reuseable to the point that the machine shop didnt recommend resurfacing it!
My big concern right now with the engagement so low is that it's hard to shift gears at redline under WOT. Have to completely bury the clutch to the floor before engaging the next gear. And even sometimes then there is still a lot of resistance on the shifter.
