HELP!!clutch install
Old Mar 22, 2009 | 12:46 PM
dvscobaltSS's Avatar
installed my clutch....goes into gear but only creaps forward. if i give i gas it goes no where. spec stage 2+ spec flywheel and new throw out bearing. any suggestions!!!
Old Mar 22, 2009 | 01:00 PM
Sharkey's Avatar
did you tighten the pressure plate bolts??? did you make sure the disc fit on the input shaft of the tranny before installing it??? are you able to put it in gear with your foot off the clutch???
id mabey try cracking the bleeder screw and see if there is pressure in the hydralics holding the release bearing on. if not, i hate to say it, but your gonna have to pull the tranny back out.
Old Mar 22, 2009 | 01:35 PM
yeah tightened it down made sure the disk fit and no it will not go into gear with foot off clutch...i will check the bleeder screw.
now with the spec clutch there was a ring around the pressure plate that came together with the throwout bearing....dont tell me that **** was supposed to come off. it didnt look like it could but i swear if it was i am going to be pissed..it was a small collar thing right around the middle
kinda like where this red mark is
here is a link to a perfect pic of it its the 3rd pic downhttps://www.cobaltss.net/forums/drivetrain-79/prices-intstalls-thread-157590/
Last edited by dvscobaltSS; Mar 22, 2009 at 01:59 PM. Reason: Automerged Doublepost
Old Mar 23, 2009 | 06:10 AM
man all kinds of views but no answers....bump
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
