help!!! coolant leaking...
Old Sep 17, 2010 | 11:29 PM
jacobrollins's Avatar
hey so i have a cobalt 2.4 le5. I just installed an obx header and catless dp, and its BAD. theres a clicking noise. and there is a coolant leak. i have no idea where its coming from. can anybody help?
Old Sep 17, 2010 | 11:30 PM
jonxxxedge1's Avatar
i had the same exact problem last year. the header flange is warped. and you have to rotate the collant crossover pipe that it hits on.
Old Sep 17, 2010 | 11:37 PM
How do you rotate it?
Old Sep 18, 2010 | 08:16 AM
put vice grips on it and twist it
Old Sep 20, 2010 | 02:59 AM
sweet....i figured it out. it was a broken seal from the waterpump. it must have cracked under the pressure when i first started it.
Old Sep 20, 2010 | 01:30 PM
kissrocker52's Avatar
so you literally just twist it and it will re connect itself
Old Sep 20, 2010 | 03:13 PM
kissrocker52, you have to loosen a few bolts on the thermasat, and then my hand you just rotate the waterpump pipe so it doesnt hit the header. i didnt know of this at first, so when i started the car, it must have cracked a seal under the pressure.
brandon04
Oct 21, 2015 07:04 AM
vjoel2011
Oct 2, 2015 12:11 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
ATOMbomb
Sep 11, 2015 10:48 AM
