help! shifter wont go in gear after clutch install
Old Feb 5, 2010 | 05:01 PM
pickin my brother up's Avatar
i had the gm ungraded clutch installed on my 05 a week ago.
when i got my car back everything worked great except now the shifter doesnt go all the way into 3rd gear position. it almost basically doesnt click into gear and will actually pop out and go back into nuetral when shifting into it unless i hold it up there (which i know is just as bad to do)
anyway, the shop said they will research on what it is that holds the shifter into gear and look at it again on monday.
i really need help on this ones because i have a feeling the shop is gonna try and pin this on me when i KNOW it wasnt doing this until after they did the clutch install.
Old Feb 5, 2010 | 05:06 PM
glen229's Avatar
did they replace the TOB?
Old Feb 5, 2010 | 11:20 PM
i had the whole flywheel and the upgraded clutch.
i believe i saw a TOB on the receipt also
Old Feb 6, 2010 | 12:50 AM
08SSTCRD's Avatar
TOB has nothing do to with your symptom.
Sounds like the linkage got out of adjustment when they removed and reinstalled the transmission. All that should be needed is a simple shift linkage adjustment to make it right again.
Old Feb 6, 2010 | 02:01 AM
hungryhip-ccp's Avatar
yep, just pop out your cup holders and adjust the shifter linkage so that neutral is farther back letting the stick travel further foward going all the way in gear without running out of throw.
put the stick in neutral to start, then look for the clips, they are interesting the way they clamp down on the shift rod. wiggle the shifter foward and backward to locate the right one. then just pry up on the grey part of the clip and make neutral further back more towards the center. then just push the clip back down where you want it to stay.
you may need to do this a few times to get it perfect.
Old Feb 6, 2010 | 03:22 PM
sounds like im just gonna go at this myself then. thanks a lot
Old Feb 6, 2010 | 03:32 PM
juststickit124's Avatar
x2, linkage problem to me
Old Feb 6, 2010 | 04:11 PM
roboticfister's Avatar
It's either the linkage, or possibly a 3rd gear synchro, maybe a fork. Mine started popping out of 5th, got it apart and discovered the 5th synchro was toast. I hope it's just the linkage, but it seems that if it was the problem, it would affect more than just 3rd gear.
Old Feb 6, 2010 | 07:51 PM
yeah, i can feel it a little bit in first and5th also but im guessing since they are off to the side it just holds it in a little better and doesnt pop back to neutral. hopefully its just the linkage.
Old Feb 7, 2010 | 02:00 PM
i cant seem to figure out how the gray clips pry off of the shift rod so that i can adjust it.
what part of the gray piece clips off and which way do i pry it?
Old Feb 7, 2010 | 02:08 PM
VeNoM0713's Avatar
here you go... look this over http://www.twmperformance.com/manual...all-manual.pdf theres a section on how to adjust the linkage with pictures.
Old Feb 7, 2010 | 02:36 PM
ok i ended up getting the piece off and adjusting it all different spots and my shifter still isnt snapping into 3rd...
so i guess it looks this is my syncros or something? this is shitty
Old Feb 7, 2010 | 04:10 PM
08SSTCRD's Avatar
Sounds like a bad 3rd gear synchro to me. Could also be a bent shift fork, but I'm not sure how common that is in these transmissions.
Old Feb 9, 2010 | 09:02 PM
so the gears are all back to normal.
apparently there was some kind of tube in the way blocking it from going all the way into the gears.
funny thing is he even said it was an after market line that was in the way lol
Old Feb 9, 2010 | 11:57 PM
oh you mean blocking the linkage at the tranny! i had that happen to me when i pulled the motor and re installed.... i was like wtf is wrong!!! it was the heater hose or break booster line i dont remember.
Old Feb 10, 2010 | 12:34 PM
im just really relieved that he figured out what it was.
def didnt wanna replace synchros right after replacing the clutch
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
