how do i remove the PCM bracket
Old Jan 20, 2010 | 12:19 AM
harryresh's Avatar
im begining to start ripping my car apart to change my clutch and was wondering how to remove the PCM bracketry to get to the upper transmission bolts? i have an '07 SS. i was reading the GM build on how to change the clutch but they are working on an Ion and that is different than the SS as far as this goes.
Old Apr 13, 2013 | 04:45 PM
FatSam2010's Avatar
Bump for same question cause I'm a straight retard!
Old Apr 13, 2013 | 05:27 PM
mongorat427's Avatar
Heres the way I did it. Disconnect the battery in the trunk. Remove the ECU move the connecters out of the way. remove the fusebox cover. disconnect the battery cables. theres 2 of them a least. remove the 10mm nut on the fenderwell. Loosen the 2 bolts under the bracket and lift the bracket up and tie the whole thing back towards the firewall. Theres enough room to get the mount bolts off and the clutch line off the trans and unbolt the shift cable bracket while your at it
Old Apr 13, 2013 | 05:31 PM
FatSam2010's Avatar
God bless you man, you're a life savior!
Old Apr 16, 2013 | 03:16 PM
harryresh's Avatar
an answer to my post after 3 years and 3 months. hahah i love it
Old Apr 16, 2013 | 03:35 PM
jonathan923's Avatar
smh noone ever changed clutches in 2010 man, your the only that did it :P
Old Apr 16, 2013 | 03:46 PM
EXsoccer1921's Avatar
https://www.cobaltss.net/forums/how-...se-box-290069/
i would advise against disconnecting the ecm though. those connectors only have about 12 on/offs in their life..
Old Apr 16, 2013 | 05:50 PM
FatSam2010's Avatar
Well **** I already disconnected all that... Hopefully I still have a few on/offs left!
SmitBag
Sep 7, 2016 08:05 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
Dustin24
Oct 8, 2015 09:15 AM
Delta coupe
Sep 30, 2015 08:11 AM
Cptnslo
Sep 24, 2015 09:32 AM
