How to properly adjust shifter? (Ottp/TWM)
Old Oct 12, 2015 | 11:07 AM
breds2k's Avatar
Hey guys, after getting my car back after installing the used 4.05 I got from Jeff Neiland (after cracking my T case on a launch), I noticed right off the bat my reverse was way out to the right, easy adjustment.
So lately ive been having grinding issues not with WOT or anything like that but simply coasting off the highway in 4th, clutch in and pushing up to 3rd clutch still in and it grinds. Also was tough to get into first at a stop yesterday, just let go of the shifter and tried again and it goes right in. AGAIN no hard shifting issues (went through all gears last night to be sure)
In addition when putting into reverse the speedometer jumps for a second. So what exactly is going on here, im assuming its a shift linkage adjustment, I do have adjustable cable clamps and a OTTP shifter, let me know what you guys think!
Thanks,
Bob
Old Oct 12, 2015 | 11:27 AM
double clutch's Avatar
If your shifter is too far forward, you might not be going completely into gear. Try moving the shifter down towards the rear of the car a bit. I used to grind in 2nd. Simply adjusted the shifter forward and inch and was good to go
Old Oct 12, 2015 | 11:33 AM
breds2k's Avatar
That's the thing im not sure which direction to play with, ive seen grinding going from fourth with the clutch in coasting just passing neutral going to 3rd gear. and in reverse both ONLY after the transmission was replaced
Old Oct 12, 2015 | 07:03 PM
My reverse started to grind after putting in a new clutch. You really just have to play with it until it feels right to you.
Old Oct 14, 2015 | 01:18 AM
LNFwagonSS's Avatar
The fact that speedo jumped tells me there is possible differential, axle, or hub issues. I would start there. Sounds like the tranny is pissed off too. What fluid was used?
Old Oct 14, 2015 | 07:35 AM
breds2k's Avatar
OEM 10-4059 GL4 ACD. Transmission has terrible input shaft noise. Goes away when clutch pedal is pressed in....sigh people keep telling me "All these transmissions are noisy" and that I worry too much.
Old Oct 14, 2015 | 10:06 AM
LNFwagonSS's Avatar
10-4055, GM part# 88862472 is the fluid you want. And is the actual oem fluid.
Old Oct 14, 2015 | 10:15 AM
breds2k's Avatar
****....Not exactly sure how that happened.
Old Oct 14, 2015 | 10:51 AM
breds2k's Avatar
So my new transmission is probably destroyed now. Thoughts on the wrong fluid being used as far as damage? It has loud input shaft noise now.... That seems rather obvious. Maybe 3000 miles on trans with that fluid
Old Oct 14, 2015 | 11:53 AM
LNFwagonSS's Avatar
That fluid you used wont damage anything. It's just not ideal.
Old Nov 3, 2015 | 12:54 AM
firehawk618's Avatar
Thanks,
Bob
Did you swap complete transaxles or just have the 4.05 FD swapped?
jas09ss
Nov 19, 2015 02:12 PM
RyBread761
Oct 15, 2015 09:57 AM
Jon Jessie Cremeans
Oct 11, 2015 02:33 PM
soundjunky
Oct 7, 2015 10:01 PM
