hurst shifter problems
i installed a hurst shifter on my car, and i feel like it shifts like ****, i mean the shifter feels like its precise and all but i feel like i need to use a bit extra force to move the shifter. I lubricated it and everything and i double checked everything and all looks good? do i have to wait a few days for the shifter to "break in"? because all of the other shifters i have installed have felt stiff for a few days after the isntall, then seem like they loosen up a few days later
You need to move the white plastic clip things until you get it right.
Use this for reference. https://www.cobaltss.net/forums/how-guide-43/how-hurst-short-throw-shifter-61492/
The clip on the linkage. unclip it move the shifter over to the pass side a bit and clip it back on. I had one of those shifters and it was a piece of **** . I couldn't wait to take it out of the car. It made 3rd gear knochy, and for reverse I had to sand the lock out gate down to make it work smooth.
Hurst droped the ball on this thing.
JUst my 2C
JUst my 2C
Use this for reference. https://www.cobaltss.net/forums/showthread.php?t=61492
there are plenty on here who are very happy w/ the HURST... including myself
The Hurst is no worse than the B&M. I had the B&M before the Hurst came out.
If I did'nt f'up my stock shift knob I would still be using the stocker. For the money
niether one is really worth it IMO.
I just helped curtis (firestorm) adjust his hurst, took 3 minutes to have it feeling exactly like stock shift points.
just like mine.
sorry guys, you can blame the part all you want, but if you dont install it properly, its not going to work.
spend some time adjusting the cables properly.
just like mine.
nah not you. but theres quite a few people who rip on the hurst shifter because they didnt install it right.
what you do, is move the shifter left to right, once you see which cable is controlling that motion....put it back in the neutral position and unclip the white clip from that cable
now move the shifter SLIGHTLY to the left, and reclip it.
see how that works.
from there its rinse/repeat until you find that sweetspot where all the gears feel like butter
see how that works.
thanks, im going to try it tomorrow, as well as start my projector retrofit. good thing i voted for you for cotm lol
i also have to fix that little ball thing with the set screw that got stripped lol, time to get out the drill
