hurst shifter problems
Old Nov 13, 2007 | 10:25 PM
anthonyS88's Avatar
i installed a hurst shifter on my car, and i feel like it shifts like ****, i mean the shifter feels like its precise and all but i feel like i need to use a bit extra force to move the shifter. I lubricated it and everything and i double checked everything and all looks good? do i have to wait a few days for the shifter to "break in"? because all of the other shifters i have installed have felt stiff for a few days after the isntall, then seem like they loosen up a few days later
Old Nov 13, 2007 | 11:02 PM
FryLoch's Avatar
Could be becuase the shifter itself is shorter, thus you have less leverage and require more force to shift a gear. Just a thought though...
Old Nov 13, 2007 | 11:07 PM
stealthy1ss's Avatar
You might need to keep adjusting it. It sounds like it might be getting hung up somewhere.
Old Nov 14, 2007 | 04:04 PM
anthonyS88's Avatar
how would i adjust it?
Old Nov 14, 2007 | 08:36 PM
You need to move the white plastic clip things until you get it right.
Use this for reference. https://www.cobaltss.net/forums/how-guide-43/how-hurst-short-throw-shifter-61492/
Old Nov 14, 2007 | 08:38 PM
anthonyS88's Avatar
white plastic clips as in the linkage?
Old Nov 25, 2007 | 05:58 PM
spaz's Avatar
The clip on the linkage. unclip it move the shifter over to the pass side a bit and clip it back on. I had one of those shifters and it was a piece of **** . I couldn't wait to take it out of the car. It made 3rd gear knochy, and for reverse I had to sand the lock out gate down to make it work smooth.
Hurst droped the ball on this thing.
JUst my 2C
Old Nov 25, 2007 | 06:00 PM
suburbanrobot's Avatar
Use this for reference. https://www.cobaltss.net/forums/showthread.php?t=61492
^^^ yep, what stealthy said!!!!
there are plenty on here who are very happy w/ the HURST... including myself
Old Nov 25, 2007 | 06:09 PM
an0malous's Avatar
9 times out of 10 any issues with short shifters is due to install.
adjustment time
hurst is hot **** when installed properly
Old Nov 26, 2007 | 04:44 PM
spaz's Avatar
I don't care what any of you say. I think the hurst shifter is a POS. 3rd gear is not lined up correctly once you move the cable to make 5th and r work properly.
Old Nov 30, 2007 | 06:14 PM
cobaltss306's Avatar
I agree I installed a hurst today and took it right back out its a BIG POS!!!! if I go with another it will b&m I do not see every one with problems out of there B&M!
Old Dec 1, 2007 | 07:06 AM
anthonyS88's Avatar
i just like the stock shifter lol
Old Dec 1, 2007 | 07:38 AM
OzzyruleZ's Avatar
I just installed my B&M last night, I'm liking it so far. Getting ready to leave for the track now. Gonna see if I need to fine tune it at all there.
Old Dec 1, 2007 | 10:40 AM
spaz's Avatar
^^ I love that racing in December. It is -20*c here.
I just cut my stock one down.5th takes a bit to get used to.
Old Dec 1, 2007 | 02:35 PM
OzzyruleZ's Avatar
man its about 80 degrees here. i'm sitting in the staging lanes right now waiting my turn
Old Dec 1, 2007 | 11:20 PM
I got my hurst to work but it took a lot of cuting ! And some adjusting to !! I still think they should istall better than they do to be a bolt on part!
Old Dec 1, 2007 | 11:36 PM
BACK2GM's Avatar
The Hurst is no worse than the B&M. I had the B&M before the Hurst came out.
If I did'nt f'up my stock shift knob I would still be using the stocker. For the money
niether one is really worth it IMO.
Old Jan 5, 2008 | 05:59 PM
07GatorSS's Avatar
is there a hurst shifter for the 2.4 yet?
Old Jan 5, 2008 | 06:03 PM
FryLoch's Avatar
I just bought mine, hope it works out...
Old Jan 5, 2008 | 06:09 PM
RollOver360's Avatar
Adjust the shifter cable.
later
Old Jan 5, 2008 | 06:41 PM
an0malous's Avatar
I just helped curtis (firestorm) adjust his hurst, took 3 minutes to have it feeling exactly like stock shift points.
just like mine.
sorry guys, you can blame the part all you want, but if you dont install it properly, its not going to work.
spend some time adjusting the cables properly.
Old Jan 5, 2008 | 06:45 PM
anthonyS88's Avatar
how do you adjust the cables, and i was not blaming the part at all
Old Jan 5, 2008 | 06:50 PM
an0malous's Avatar
nah not you. but theres quite a few people who rip on the hurst shifter because they didnt install it right.
what you do, is move the shifter left to right, once you see which cable is controlling that motion....put it back in the neutral position and unclip the white clip from that cable
now move the shifter SLIGHTLY to the left, and reclip it.
see how that works.
from there its rinse/repeat until you find that sweetspot where all the gears feel like butter
Old Jan 5, 2008 | 06:54 PM
anthonyS88's Avatar
thanks, im going to try it tomorrow, as well as start my projector retrofit. good thing i voted for you for cotm lol
i also have to fix that little ball thing with the set screw that got stripped lol, time to get out the drill
Old Jan 5, 2008 | 06:55 PM
an0malous's Avatar
ive heard a few guys who had that problem picked up a new setscrew at home depot
