Hurst Short Throw
I don't really care that much either but when you have 5 people telling you the that adjustment is where people screw up and he still doesn't get it then you have to call him a retard (I mean really Corky from Life Goes On could have figured it out by now) and then he went and called out one person and says they argue just to argue and then he evolves into a retarded jackass. Some people just need to QFT!!!
You need to go back on permanent ban...You're the one who came in here causing trouble
Here are the three posts before you threw the hissy fit telling you that the adjustment is what people screw up on...
AAAAAAnd here are the three after you made a *** bubble out of yourself...
The problem comes in the adjustment of the cables. Doesn't seem like something that should be that hard to do, but appearantly it is. Some people adjust too far left or right, then have trouble finding 1/2 or 5/R, some adjust them too far forward or back, either bumping into the cupholders in front or getting it so far off that there's not enough room to fully engage certain gears. It's something straightforward but a lot of people screw it up. And yes, I've seen people install short throws SO sloppily that the entire shifter feels like ****. How you can manage that, I haven't a clue, but it happens.
Look jack ass people don't know how to adjust it correctly. Can you just slap it in and have it kinda work....yes. If you don't adjust it properly 5th gear is all fucked up and your reverse lock out is all fucked up. It takes time to set it up properly and most of the wanna be ricers don't take the time to do it...
Last edited by Tazmanian_Dvl; Jul 29, 2008 at 11:57 PM. Reason: Automerged Doublepost
Calm down children. Now it looks like I'm one of the jackasses that can't install a shifter properly. 1st and 2nd line up fine, but 5th and reverse aren't. I have to hunt for them a bit. What needs adjustment to get those gears and stops lined up?
Sorry to thread jack, but from the looks of things it couldn't hurt.
and who cares about the shifter cables. this is about throw. and the B&M is shorter and shift/feels better.
First, Hurst Designed this shifter BEFORE B&M purchased the company Hurst. So they are 2 different designs. The design has been the same since the first day they released them.
Second the B&M, has been stated, 100's of times, that it shifts more smoothly, and I WILL AGREE, the B&M shifts much smoother. Only thing I like on the Hurst is the shift knob is a bit "more likable".
But as far as performance goes, B&M all the way.
I've installed three of these shifters and had no need to adjust any. When I install the shifter I do not disconnect the cable at the white connectors. I remove the cupholder and use a screw driver to remove the cable pivot socket from the shifter.
When I install the shifter, I lube the pivot ball at the bottom of the Hurst. I put a piece of wood under the shift cable through the cup holder. Then I push the shifter pivot ball into the cable.
At the some token, I drill and tap the hole for the set screw to make it larger so the shifter does not pivot when it is installed.
OK so I went out and took a picture of the cables for everyone and this is the cable you need to adjust (circled in red)...
Take a sharpie marker and mark the shaft of the cable directly in front of the white connector I have circled (Gives you a reference point to go back to if it gets worse or you want to go back to the stock shifter). The pull up on the tab at the front of the shifter and you can then move the shaft of the shifter cable in and out without moving the shifter. In my case 5th gear was way far to the right when compared to the other gears and 5th gear lock out still worked but the cable was stretched to the max. I moved the cable only about 1/4 out of the connector and locked it and tried it out and it was pretty much perfect. If you have problems with how it sits front to back you would basically do the same thing with the other cable until it was in the position you desired (I didn't have to adjust front to back travel when I installed mine). I would only do adjustments in 1/8" increments so that you don't adjust it too far the other way. Well I hope this helps...
For those who want the Hurst Shifter here is a link to a sale we are running.
https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/hurst-sts-hurst-sts-hurst-sts-hurst-sts-hurst-sts-hurst-sts-126219/
Cptnslo
Sep 24, 2015 09:32 AM
SS_2009_TC
Sep 11, 2015 05:41 PM
