I think i have a problem?? HELP
Old Nov 25, 2011 | 10:33 PM
iceman_06's Avatar
OK guys, I am all bummed out. I have picked up a rattle in the top end of my engine on the right side by the pulleys. (Right side when in the car; left lookin at the engine from the front bumper.) I have no check engine lights, all fluids are clean, and the only noticeable thing to me is it seems to have less power. It's getting 22.8 miles to the gallon now and I can tell from the exhuast that I am running a little too rich. The mods I have are a weapon r intake, a flowmaster super 44....everything else is stock. I know you guys can't hear it but it's a rattle and not a rod knock. I'm sure it's in the top end of the motor. Also I put some Lucas heavy duty oil stabilizer in it. Its not near as loud now and that was just to get me home. Any input would be VERY much appreciated.
Old Nov 25, 2011 | 11:35 PM
iceman_06's Avatar
i have it parked and there are no leaks gonna tear into it on sunday......anyone have any ideas???
Old Nov 26, 2011 | 12:10 AM
alleycat58's Avatar
You sure it's not the tensioner. IIRC it's on that side of the engine.
Old Nov 26, 2011 | 01:43 AM
iceman_06's Avatar
no i am not sure but i willl check it just seems to me to be comming from the top of the engine but thank you i will check i am so bummed out right now
Old Nov 26, 2011 | 01:45 AM
JustACobalt's Avatar
could be the tensioner but the belt would prob slip if it was loose
Old Nov 26, 2011 | 01:49 AM
iceman_06's Avatar
well as far as i can tell its no slippin and i havent thrown the belt.....
Old Nov 26, 2011 | 10:23 AM
Powell Race Parts's Avatar
CED sell the timing chain tensioner its under 100 delivered to your door, its ez to install and I suspect your noise will go away when you install it. Good luck
Old Nov 26, 2011 | 11:01 AM
joshcsepegi's Avatar
That is the same thing that mine did. I replaced the tentioner and all is good
Old Nov 26, 2011 | 12:09 PM
iceman_06's Avatar
timing chain huh wow thats one i hadnt thought of thank you very much!
Old Nov 26, 2011 | 12:20 PM
iceman_06's Avatar
how much of a pain is it to do the timing chain tensioner guides and sprokets cause i found the whole kit for 150 at a local parts store
Old Dec 5, 2011 | 12:08 PM
iceman_06's Avatar
ok so i did the tensioner and wa la now more but for good mesure and since i was that far i also repalced the guides, timing chain, and the gears worked great thanks for help and advice you guys rock!!!!!
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
