Idle Problem with my SS
Old Dec 28, 2008 | 12:38 AM
bluesheep2021's Avatar
I have 2006 SS S/C, I recently installed a stage 2 kit, and also have a k&n typoon on it as well as a catback exhaust. before doing any of the preceding work I was having a problem with my idle. i would be coming to a stop and put the car into neutral and the RPM's would go real low then recover, but sometimes the cr would almost die at the stop. I've tried cleaning my throttle body and have had the PCM flashed as per a TSB from GM, and i have had the ECM flashed for the stage 2. Any suggestions?
Old Dec 28, 2008 | 01:07 AM
Cefaln452's Avatar
subd'
Old Dec 28, 2008 | 01:15 AM
Area47's Avatar
Rent me! per hour
take the throttle body off the car. there is a small hole on the back side of the body itself. spray carb cleaner in this hole.
Old Dec 28, 2008 | 01:20 AM
RooTBeeR's Avatar
yeah, i was gonna say that too, clean the throttle body really well...maybe give the MAF sensor a a lil cleaning too, wouldn't hurt
Old Dec 28, 2008 | 01:35 AM
bbbevans89's Avatar
there is also a reflash your dealer can do for you they did it for me fixed the problem a little but not perfect.
Old Dec 28, 2008 | 06:42 AM
I'll try that out. I was actually driving tonite and it did the same thing it did after i flashed the PCM as per the TSB, which was basically re-learn itself, it hasn't had the problem all night, I'll spray the TB & MAF anyway, thanks.
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
