Ingalls Noise Fix
Ingalls Noise Fix
The cause of the noise seems to be the small bracket hitting the motor mount. The contact occurs on the part of the bracket that is facing the engine. When you install the bracket make sure you pull the bracket away from the engine when you tighten it down. You may want to grind the holes to give you a little more clearance. I only moved the bracket away and the noise on left hand turns went away.
Hope it works for everyone
DANRICKARD
Oct 1, 2015 12:08 AM
