Installed clutch in Gdubs LNF
Old Dec 19, 2011 | 09:10 PM
09xfebalt's Avatar
Well Geoff(gdubs) brought his car in to the shop to have his transmission replaced for shifting problems. He was iffy on replacing the clutch at first but now he is very happy he did because the stocker was shot. Some points I want to add. I installed the GM clutch upgrade on a 2007 SS( flywheel, disc, pressure plate) and I must say the install of his spec clutch was alot easier and went alot smoother. The only issue I had run into was the fywheel was worn very uneven so I took it to a friends machine shop to have it resurfaced. After instalation I was very impressed with the engauging and pedal feel of the clutch he bought, 6 puck with a sprung hub. Car had 29,xxx on it and this is how beat the cluth was.
Old Dec 20, 2011 | 01:48 AM
Boosted4's Avatar
Cool. Always good to see a new aftermarket clutch going in. Now comes the lame break-in period with no fun "spirited" driving
Old Dec 20, 2011 | 02:31 AM
BlkWdoSS's Avatar
nice install, that other one was beaten pretty nicely
l8r,
PD
Old Dec 20, 2011 | 04:52 AM
AndrewSS/TC's Avatar
What all has to come out to pull the tranny out of the car?
Old Dec 20, 2011 | 06:20 AM
09xfebalt's Avatar
Cradle and fuse block
Old Dec 20, 2011 | 06:54 AM
FrossB's Avatar
Thread Killer
Shoulda done a How-To of the install for the LNF! Because i am having trouble justifying paying 5-600 bucks for install haha
Old Dec 20, 2011 | 09:45 AM
gdubs's Avatar
Either I suck at driving stick. Or. My car has too much power for the clutch. Surprisingly I still had no slip
Old Dec 20, 2011 | 10:56 AM
Boosted4's Avatar
You suck at driving stick and didn't realize it actually was slipping
Old Dec 20, 2011 | 11:05 AM
Dart_SI's Avatar
theres a pdf file on how to do a clutch step by step for the lsj. just use that, i did. not worth paying 600 bucks when you can do it yourself if you have the tools.
Old Dec 20, 2011 | 11:23 AM
Empty Pockets's Avatar
this.
Old Dec 20, 2011 | 11:43 AM
alerosaint's Avatar
link??
Old Dec 20, 2011 | 01:13 PM
gdubs's Avatar
Originally Posted by Empty Pockets
this.
thanks tom....
hate u for life!
Old Dec 20, 2011 | 02:24 PM
gdubs's Avatar
Well I have the car back and here are my thoughts.
What i bought was a Cluchmaster Stage4 6 puck. Its very nice. Feels just like stock should, pedal is very easy nice a light. I have a tiny bit of chatter if i keep the RPM low from start.
Over all a fantastic buy
Old Dec 20, 2011 | 02:31 PM
donkeyballs's Avatar
My clutch will chatter when cold so i try to let the car warm up real good before moving it.
Old Dec 20, 2011 | 02:37 PM
gdubs's Avatar
Thanks donkeyballs! hows ur balt running?
Old Dec 20, 2011 | 02:42 PM
vahdyx's Avatar
So is your transmission okay? Or was the problem all due to a bad clutch?
Old Dec 20, 2011 | 02:44 PM
gdubs's Avatar
Transmission and clutch were replaced. Both were causing a problem that made each other more pronounced
Old Dec 20, 2011 | 02:50 PM
Its been good actually and after taking care of the boost leaks i haven't had to touch the tune in months. I still need to detune it for winter but i'm gonna wait till it really starts to snow.
Old Dec 20, 2011 | 02:58 PM
vahdyx's Avatar
I have issues getting it into first and reverse is this normal. Also my car jerks sometimes if I let off the clutch fast or if I'm in second and let off the gas. Normal? Or did I just get an excuse to buy ZZP S1 tranny?
Old Dec 20, 2011 | 03:01 PM
Thats normal.. Put it in 3rd first to slow the input shaft then put in rev or 1st.
Old Dec 21, 2011 | 06:14 AM
BlkWdoSS's Avatar
The GM Build Book would be extremely helpful, I know there with be a few differences from the LSJ to the LNF but should be a good outline of the route you should take. Ive done the swap so many times that I can have the trans out and on the floor in <45mins.
l8r,
PD
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
