Installing stage 2 mounts
Old Nov 3, 2010 | 12:53 PM
30odd6's Avatar
i'm puttin in stage 2 ottp mounts soon using my friend's garage (and his lift), were not using jack stands.
anyhow can i loosen passenger side engine mount bolts first, THEN lift car and put jacks underneath oil pan and trans? (rather than vica versa, as suggested)
is it ok to do a final tightening of front and rear mount bolts, THEN lower car and tighten motor mount bolts? (again, instead of vica versa as suggested)
and lastly, can i just lower car and pull forward and backward a couple of inches (to settle everything) then lift and trq to spec? or can u just rock tranny/motor before final torqing?? thank you
Old Nov 3, 2010 | 03:32 PM
Iam Broke's Avatar
I think that will work ok, I had some issues getting the trans case bolts back in for the rear mount so I had to use a prybar to move the engine around a bit. Drove it a day, loosened up the bolts and retorqued them all. Really didn't notice any difference before vs. after the retorque.
Here's the info you seek on the torques
https://www.cobaltss.net/forums/4331857-post22.html
Old Nov 7, 2010 | 06:29 PM
tomj77's Avatar
why would u put jack stand under the oil pan? u crazy?
Old Nov 7, 2010 | 06:34 PM
Iam Broke's Avatar
I missed that , OP should support the trans & engine but not by the oil pan.
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
