Kinda confused ... wheel hop issue.
Originally Posted by Cynic/Torque Forward
The Torque Forward Dual Brace braces both sides of the powertrain. One on top, one below and they're each on opposite sides.
Is the price quoted for both sides? Or do you have to buy 2??
Originally Posted by FAST06SS
I have never seen a pic of the tranny side install??????
FAST06SS Please answer my ?!
Non Authorized / Non-Supporting
Looks good. What keeps the braket from rotating on the bolt?
Ben
Originally Posted by dirtySSout
I liked to know as well! Kinda wierd if you ask me....
He's been running it on his car since we came out with it. My car is in storage until next Friday.
He said that the torque of the bolt actually keeps it in place. He's been drag racing with it (how he blew his motor) and auto x'ing and he said it hasn't moved any on him. He said if you're concerned (and you don't need to be) you can drill a hole and put a pin through it.
Like I said..he's an engineer for a steel plant and a lot of your guys know him. Name's Rice Eater on redline forums. He's never steered me wrong.
hope that helps!
Ben
Im not convinced yet. I rather get wheelhop than put something like that on my car. If your unsure just wait. The solution is yet to come.
PS. Is it just me or are vendors getting kinda negative on these posts lately?
#36
As for the negativity issue, I'm an individual like the rest of you and if someone attacks me I defend myself. I'm honest and fair and there's no need to make a scene if you have an issue. Just talk to me, we'll work it out.
#37
Moderator Alumni
Moderator: I would suggest that you not bash a PAYING vendor's product especially when you are referencing the wrong product. It's no longer a Vita brace. It's a Torque Forward brace and it's completely different. Thanks
I never said you were vita, infact the only person associating torque forward with vita is you. My reply was a direct response to the question posted by JCM.
#38
I have the JBP control arm bushings and the ZZP passenger side poly mount. I still have wheel hop. I am going to go with the intense front and rear mounts for $99 unless the Torque Forward is less for the two damper setup.
#39
The bottom dampner is in the middle of the eng/trans torque area. You STILL need one at the tranny end on the drivers frame rail. It does not good to put a mount on only half the rotation axis. My opinion from expierence.
Now design one for the other end and you have a nice set-up
#40
I have the ZZP Billet Engine Mount and the ZZP front tranny mount. I now have virtually no wheel hop. The car was louder on the inside and did have some awful vibrations inside too. But that wore off after a month. There still are some minor vibrations, but I will definatly live with it for the results that I got.
#41
#42
From what I can see on the torque forward dual setup, they are going to take care of damping the rotational moments along the cross car axis. Since our engines are mounted transverse, this is the axis that the overwhelming majority of loading will occur (torque moments from the changing torque of the rotation of engine and driveline). Cynic, I know you are not an engineer, so be aware that on this car, the engine cradle is the frame rails in the front of the car.
