KY Clutch owners
Old Jul 22, 2011 | 09:30 AM
jphugel11's Avatar
KY Clutch owners
Ok, I know this has been almost an overtalked part, but I recently got tuned with the new hptuners software and am putting out 362wtq and need a new clutch. My stocker started slipping on the first tuned pull, so I don't really have accurate dyno numbers. Wtq seems about right, but hp was way off I have a feeling. Basically though, I know I need a good clutch and have heard many positives about KY clutches, with minimal problems and am looking to hear owners and users of this clutch opinions and any problems they have had with the clutch, thanks in advance!
Old Jul 22, 2011 | 09:34 AM
jphugel11's Avatar
Edit: my car is a daily driver year round, so I also was wondering if anyone happens to have some cold weather experience with this clutch?
Old Jul 22, 2011 | 09:56 AM
vahdyx's Avatar
Only thing negative I've heard was that the disengage point is near the top, so you barely push the clutch and its off. I heard this is fixed with ZZP clutch rod though.
Not that this helps, but I hear Clutchmasters Stage 3 is identical to stock and holds more than stock by a good number but KY holds even higher. So if you weren't planing on going to high like BT clutchmasters will work. KY will work even if you go BT. This is hearsay for me, I couldn't prove it if you asked.
Old Jul 22, 2011 | 10:21 AM
jphugel11's Avatar
Haha ok, I appreciate the reply, that's just about what I've heard too. Hopefully I get some actual users too. Lol.
Old Jul 24, 2011 | 05:23 PM
NDCOBALTSS's Avatar
I've had my KY clutch in for 1700 miles can not get it to hold more than 320 ft lbs of tq, broke in properly too, im working on getting a new one, i heard they have great customer service!!! hopefully if i get a new one, it works..
Old Jul 24, 2011 | 09:56 PM
vahdyx's Avatar
Yeah, well I've decided to get a ZZP clutch instead. I want it to work and be great. I figure an extra $300 isn't gonna hurt.
Old Jul 25, 2011 | 01:23 AM
JacBlackSS/TC's Avatar
i have had mine for a while got a decent amount of miles on it and i can say that the only issue that takes some getting use to is the noise which i hear is common with puck clutches and the engagement, its very on and off the pedal is much lighter than stock
and as far as power mine is holding 370+ wtq just fine
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
