Linkage problem?
Old Dec 14, 2009 | 10:16 PM
DarkChild's Avatar
Linkage problem?
Today I had my brother pick the car up from the muffler shop and on his way home he could only get 1,3,5th. I've had sloppy shifter problems since I got the car. It manuvered while in gear. Could this be on the tranny or under the centre console?
Old Dec 14, 2009 | 10:21 PM
JPizzle's Avatar
Most likely it is the shift linkage. Is this an SS/TC? What model is your Cobalt?
Old Dec 15, 2009 | 07:30 AM
DarkChild's Avatar
Mine is supercharged. I know it's the linkage but I
Am wondering where it might have slipped. Apparently getting a short shifter helps?
Old Dec 15, 2009 | 02:06 PM
qwikredline's Avatar
roll pin at the shifter rod under the fuse box prolly
Old Dec 15, 2009 | 09:06 PM
DarkChild's Avatar
I think it is the the roll pin. I will check to make sure. I just wanted to see if this is common with our cars
Old Dec 15, 2009 | 09:51 PM
do a search ralliartist did a how to replace....
Old Dec 16, 2009 | 11:07 AM
Maven's Avatar
Good luck, I hope its your roll pin. That could easily be an internal issue
Old Dec 16, 2009 | 02:33 PM
advise's Avatar
check the rubber boot on the linkage under the fuse box my came loose and had the same problem
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
