LNF revised shifter bracket install question
Doing this right now. Just wondering how to get the cables off the old bracket. Is there a release mechanism or do I just pop them off with force?
Thanks for any help.
-Nate
-Nate
Too bad I read this now.... I ended up giving up and puuting everything back together. I guess now that I know how to do it I'll give it another go..... Man it's tight in there..
Helps with two people. One under the car pushing up/prying with a small screwdriver and another with a long screwdriver pushing from the top. This method worked on my car and my friends car a week or two ago when we did his.
Points: 2,870, Level: 32
Level up: 80%, 30 Points needed
Activity: 1.9%
Member #: 56801
FOUND THE ISSUE why some are having difficulty removing the cables from the bracket: As you access the shifter bracket through the wheel well, the cable bracket that is closest to the drivers side (the lower cable/3-4 gear) can't be removed until the cable above and behind it (1-2 gear) is released from the bracket first. The slide lock on the upper cable, due to clearance issues, keeps the lower (3-4 gear) cable from popping out of the bracket.
Do yourselves a favor and unbolt the upper and lower bracket assembly, pull the lower bracket out of the car, so that you can maneuver the upper cable bracket around and release the upper/1-2 gear cable FIRST. Now the lower one will pop out when released.
Activity: 1.9%
Member #: 56801
Turbo Johnny
Feb 21, 2019 09:41 AM
Cptnslo
Sep 24, 2015 09:32 AM
