Lsj keeps popping the crank shaft position sensor relay after removing motor
Old Mar 26, 2018 | 12:06 AM
Chanyeezy's Avatar
So I recently dropped my motor to do the f23 swap. I have the entire harness hooked back up and when I go to jump it to start it because to battery is dead it keeps popping the crank shaft position sensor relay. (Side note, I did not unhook the crankshaft position sensor when I removed the motor) with that being said, I'm grounding it to a different nut instead of the shock nuts/bolts. I didn't see any other relays go off at all. What could I have hooked up incorrectly and what else could be the issue?
Old Mar 26, 2018 | 07:45 AM
jdbaugh1's Avatar
Where are you now grounding the cable you are saying you moved to a different mount location? Any possibility it isn't making good contact? People on here have access to electrical diagrams that may help in diagnosis so hopefully one of them chimes in.
Old Mar 26, 2018 | 02:12 PM
Chanyeezy's Avatar
The harness is grounded to a different spot on the transmission now, ground seems fairly tight. When I go to jump it I'm grounding to a nut on the body. Could be likely it's not grounding properly in either place. An electrical diagram would help tremendously that way o can double check all my connection
QuickSilver_SS
Sep 11, 2016 10:48 AM
Robles14
Dec 3, 2015 02:28 PM
nukem419
Jul 31, 2013 01:39 AM
blackss2.0
Sep 26, 2008 03:18 AM
kanabrewski
Oct 17, 2006 08:24 PM
