Manually shifting an auto. Ok to do often?
Old May 21, 2008 | 08:47 AM
  #76
OrngBalt's Avatar
Originally Posted by steddy2112
I would say because you are a Mets fan but who did I quote?
Not you
pare_john
ahh, ok... you quoted his comment that was aimed towards me. understood.
Just watch those Mets comments.... We do have a common enemy as I am an utter hater of the red sox. Being from NJ I'm guessing you a Yankee fan
Old May 21, 2008 | 08:51 AM
  #77
steddy2112's Avatar
I don't need to say anything
Phillies do all the speaking for me
Last edited by steddy2112; May 21, 2008 at 08:51 AM. Reason: Automerged Doublepost
Old May 21, 2008 | 08:55 AM
  #78
JPizzle's Avatar
Originally Posted by joeworkstoohard
it depends on the car.
basically, the lower settings on the selector open or close valves that limit what it lets the car do. in other words, you're not picking a gear, you're telling it to NOT go into the next one. when you upshift, you force the car to shift because you slam that valve shut. you should never shift a normal automatic at WOT (or any car).
also, most stock cars, putting it in drive and keeping your foot on the floor is just as fast as dicking with it.
Except for certain Trans-Am's.....
Old May 21, 2008 | 09:08 AM
  #79
OrngBalt's Avatar
Phillies? Sorry about that. You don't have a leg to stand on. You are still the losingest franchise in sports history, You haven't played well this year, you didn't play well last year. You did not win the division last year, we lost it. If we play .250 ball, we win by 4 games.
lol... I do not want to get into a baseball argument now.
Old May 21, 2008 | 06:12 PM
  #80
Panici's Avatar
Originally Posted by 1BADSS/SC
youre not really benefitting from it. When you drive an auto, it shifts through all the gears for you. Thats the point of them. Trying to manually shift an auto if anything will make it slower because the tranny takes time to adjust to the gear you switched it to, not to mention the increased chance of slippage. If you wanted to shift, should have gotten an manual. You could convert the tranny to manual, or electronic shift.
1. Not racing, just trying to enjoy the car.
2. Read the original post, it's not my car, and my daily driver is a stick.
Thanks for the advice guys, i'll continue to upshift then i guess!
Old May 21, 2008 | 09:34 PM
  #81
Red07SSNA's Avatar
"fact of the matter is, take 2 cobalts, give them the exact same mods and exact same hp, with good drivers, the manual will win every single time. and you can't argue that, because it's a fact, not an opinion."
Except for those "missed"shift runs -- won't win those timesand that too is a fact!
Would make more sense for stick lovers to avoid threads by autotranny owners. I promise not to give advice to stick owners.....
Old May 21, 2008 | 10:25 PM
  #82
an0malous's Avatar
a stick driver can drive both.
Old May 21, 2008 | 10:49 PM
  #83
HackAbuse's Avatar
I can drive both?
Old May 21, 2008 | 10:51 PM
  #84
an0malous's Avatar
congratulations.
you got the point entirely
Old May 21, 2008 | 10:57 PM
  #85
D4u2s0t's Avatar
i said good drivers. not some schmuck that doesn't know what he's doing.
let me rephrase that. the manual cobalt will always be faster, taking driver error out of the equation. a shitty driver in a very fast car can lose to cars it should lose to. doesn't mean the car is slower. it just means the driver sucks. i'm not knocking automatic cars, i've had my share. but that's the way the cobalt is.
Old May 21, 2008 | 11:21 PM
  #86
bridfi's Avatar
to each their own, if you want an auto, get an auto. plain and simple. who cares what some people on an internet forum say..
just look at hack's car... 1 pretty quick auto
Old May 21, 2008 | 11:35 PM
  #87
HackAbuse's Avatar
Uh-oh, here come the nitrous haters after that comment.
Old May 22, 2008 | 09:36 AM
  #88
1BADSS/SC's Avatar
If you want to enjoy it, and you dont care about it breaking, feel free. Like I said though, its not going to make it go faster than if you just kept it in drive. You could tune it to make it shift at peak points, but if its not yours then dont worry about it.
Old May 22, 2008 | 10:53 PM
  #89
an0malous's Avatar
all true.
but the argument wasnt over preference, it was over functionality.
no one begrudges someones choice of an auto.
its when people try and argue that an auto is better in terms of pure performance that people disagree.
Old May 22, 2008 | 10:54 PM
  #90
HackAbuse's Avatar
Originally Posted by an0malous
all true.
Noone is saying an auto is better
I beleive that they are equal.
Old May 22, 2008 | 11:08 PM
  #91
an0malous's Avatar
Originally Posted by massivematt
AUTOMATICS ARE FAR MORE EFFICIENT IN A 1/4 MILE. you will run consistent times more often. Most all bracket racers and econo dragsters use 2 speed powerglides.
Originally Posted by HackAbuse
Auto's laugh at you when your clutch starts slipping, when you lose boost when you shift (turbo) and when you have to let off nitrous to shift
Old May 23, 2008 | 08:07 PM
  #92
Red07SSNA's Avatar
I respectfully disagree with your opinion on Automatics and shifting Vs positioning it in "D". All automatics, including the Cobalt's, benefit when you use "L" because the internal line pressure is higher and the low/reverse piston is put into play. The low/reverse piston is not used in "D" -- In fact on the Cobalt this happens when you position the shifter in "I" also. This helps the low end performance as it sets up the tranny to take more torque from the engine. If you have it in "L" it will shift by itself (regardless if you want it to or not) into second at redline -- right-on-time and faster then the driver can. It is tuned for maximum performance -- I really believe after driving my Cobalt in "L" and "I" that some "GEAR HEADS" actually had some input into this setup because it is really performance-minded
Old Jun 4, 2008 | 09:11 PM
  #93
Panici's Avatar
Just a question.
When 'my friend' manually puts the trans in L and uses his ShiftPlus on 2, you can hear what sounds like a fluid 'pssshhh' when it shifts.
The sound is slightly noticeable on the 1-2 shift (WOT) in "L", but is most noticable on the 2-3 shift (WOT) in "I"
What is this sound? Is it bad? My friend rarely runs the car with mode II on, but when he does, you can always hear the sound.
Old Jun 4, 2008 | 10:02 PM
  #94
Red07SSNA's Avatar
Just a question.
Hard to diagnose over the internet...you sure its not the tires spinning? It could also be a loose serpentine belt -- they can make an odd noise at the shift when they are loose because of the change in engine speed. There is also the possibility of converter chain "slap".
Old Jun 4, 2008 | 10:35 PM
  #95
Panici's Avatar
Nope it's definitely not tire spin on the 2-3 shift. It almost sounds like a fluid squish sound, it's hard to explain.
I'll try and get a video or sound clip for you.
Old Jun 4, 2008 | 10:41 PM
  #96
Red07SSNA's Avatar
On my SUV I can tell when the serpentine belt needs changing because when I "get on it" the belt will make a fast "Swish" sound at the shift -- and it sounds like a fluid type noise. When the belt starts to get loose it only makes this sound when in WOT at the shift points too. The first time I heard it I thought it was the tranny slipping. That is the only thing that comes to mind from the noise you described.
Old Jun 4, 2008 | 10:42 PM
  #97
HackAbuse's Avatar
I get that sound all the time.
I think it's either the accessory belt slipping due to the harsh change in RPM, or something to do with the throttlebody
Old Jun 4, 2008 | 10:46 PM
  #98
Panici's Avatar
Hmm, i'm not sure if it's the belt or not.
The 'balt has just under 2000 miles on it, so it's barely broken in still.
I really only notice it in the 2-3 shift, probably because all I hear on the 1-2 shift is tire chirp!
Old Jun 5, 2008 | 03:25 PM
  #99
Turbo06Sedan's Avatar
Shifting anywhere in Drive, I or L is perfectly safe. Why? Its electronicly controlled.
No additional wear/tear is being done to the transmission(atleast on these).
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Oct 1, 2015 10:00 PM
2009blackSS
Sep 30, 2015 05:57 PM
