Mastershift paddle shifter system review
Old Jul 31, 2008 | 01:36 AM
bolus's Avatar
I installed a paddle shifter system from Mastershift into my Atom. Since I have the same engine and transmission from the Cobalt SS I thought you guys might be interested.
www.mastershift.com
The system is bascially a box that connects to the existing shift cables. When the paddles are pressed, the mechanism in the box shifts the transmission mechanically into the gear selected. The clutch remains the same and still has to be pressed between gear shifts. I have it configured so that paddles shift up and buttons shift down.
you can get it with a sequential gear shifter instead
The system knows when the clutch is pressed, so it only shifts when the clutch is down. It behaves like a sequential shifter - one click - on gear change. Multiple clicks will shift ahead or back the same amount of gears.
You can pre-shift as well. You hit the button and then it waits for the clutch to be depressed before shifting. For example, you can be accelerating in second gear. Hit the paddle and keep accelerating. Then when you are ready to shift you just depress the clutch as fast as possible and it times the shift perfectly.
It is very fast and it will shift just as fast as you can press the clutch down and release it
So far I've not had any problems as long as I am paying attention to what gear Im in. I've miss-timed a clutch and shift and the system has a built in safety function that puts it into neutral to avoid grinding the gears.
I only know the cost for the system installed in my car. It took some customization to get it in. It has a custom mounting bracket and some custom wiring so that I can still remove the steering wheel with the quick release. So I would estimate the cost to be somewhere between $2-3K
Here is a video with a demonstration of running through the gears.
http://www.youtube.com/watch?v=4KCBZxPNKyw
Here is the user manual to give you an idea of options changeable by computer access to the box
http://bolus.shackspace.com/atom/tur...fterManual.pdf
Old Jul 31, 2008 | 01:41 AM
SlowBalt_06's Avatar
nice that be sweet and ibtl
Old Jul 31, 2008 | 01:45 AM
bolus's Avatar
wasn't meant to be an advertisement, Im not selling it, just a review since I've received several questions
Old Jul 31, 2008 | 01:46 AM
any pics of your car?
Old Jul 31, 2008 | 01:48 AM
bolus's Avatar
https://www.cobaltss.net/forums/show...ght=ariel+atom
Old Jul 31, 2008 | 01:51 AM
now ..is there any advantages to the paddle shifter over the regular shifter
Old Jul 31, 2008 | 01:53 AM
ls1fbody's Avatar
Haz l33t wheelz.
sounds cool!
sweet atom btw.
Old Jul 31, 2008 | 02:05 AM
bolus's Avatar
You dont take your hands off the wheel to shift and the shifts could be faster since you dont have to time the shift. basically poor-mans sequential transmission for the track
Old Jul 31, 2008 | 02:06 AM
nice
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
jas09ss
Sep 26, 2015 01:06 PM
