MU3 Fluid
Old Feb 7, 2008 | 09:53 AM
redlineblueline's Avatar
MU3 Fluid
The question has been asked various times. What is a good aftermarket replacement for the stock GM fluid in the MU3 Transmission? And conjecture is its 75w90, or syncromesh, or ATF , etc. The GM part number escapes me but according to GM Powertrain the MU3 uses Castrol Burmah BOT 0063...I have a email into Castrol to get the specs on this fluid and will post those when I get them. However I have researched this and come up with the GL-4 standard in other places...this means the fluid could be 75w90, or 80w90. If anyone has any specs on the BOT 0063 they would be appreciated.
Old Feb 7, 2008 | 11:11 AM
Sergio's Avatar
You'll get some people swearing by the Royal Purple stuff but seeing as a few of them have gone through a couple of trannys that should ring some bells.
I would use exactly the same fluid it came with. It doesn't matter if it shifts "way smoother". If a fluid switch is changing the feel of the tranmission that much vs. stock then clearly that fluid is alot different and most likely out of spec.
Stick with the reccomended stuff as its been tested thouroughly for years and you'll enjoy a lasting transmission.
Old Feb 7, 2008 | 02:48 PM
well according to castrol who makes the GM fluid for the MU3 there is NOT an equivalent to it
so 75w90 is NOT equivalent
because they make a synthetic 75w90
http://www.castrol.com/castrol/secti...tentId=7036193
Old Feb 7, 2008 | 03:13 PM
Omega_5's Avatar
... your absolutely right...
From Castrol's website
SAAB
9-3 Series, 2.0 Litre Turbo Eng., 5-Spd. Manual/ 5-Spd. Auto. (2005-2008)
Manual Transmission
Service Refill Capacity: 1.6, 1.9 Litres (See Note 664)
Notes
664 Use only SAAB Synthetic Manual Gearbox Oil MTF 0063. Must NOT be mixed with other oils.
Old Feb 7, 2008 | 03:15 PM
yep there is no equivalent to the BOT 0063
Old Feb 7, 2008 | 03:27 PM
Sergio's Avatar
Nice job, thats some convincing proof.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Sep 29, 2015 11:07 PM
Cptnslo
Sep 24, 2015 09:32 AM
Sean Cummings
Sep 11, 2015 09:35 PM
chris88z24
Sep 8, 2015 01:55 PM
