MU3 help???
Old May 4, 2012 | 04:03 PM
NinjaHampster's Avatar
Question MU3 help???
Took apart the trans to replace a few parts but now that I am putting it back together, I am stuck on this one piece. The old one broke so I got a new one from the dealer and well this is where my problem lies. With the ring off the synchro sleeve will slide down on the gear no problem (like its supposed to do) but when i put the ring on it stops it. anyone have any idea or ran into this problem before and have any insight? all help would be appreciated thanks.
its the skinny one
(Edit: this is 5th gear)
Old May 4, 2012 | 04:32 PM
Old May 6, 2012 | 04:19 AM
a million members and nothing...... -__-
Old May 6, 2012 | 06:25 AM
Powell Race Parts's Avatar
fifth gear can be a tight fit on the splines, needs a good drift and a hammer assuming nothing is screwed up inside. You have installed a new crush sleeve? If not stop dont go any further as without it, re using the old one the trans will be so bad it will be coming out again....good luck
Old May 6, 2012 | 06:37 AM
On some transmissions, there are two small spring steel clips that fit inside the 5th gear set thatI think are basically anti rattle clips, discard those; if you installed them back in they may be getting in the way. If I could get my photobucket to work i would post pictures but cannot.
Old May 7, 2012 | 01:26 AM
are you talking about the three part that look like ---> (
Old May 7, 2012 | 07:20 AM
yes.....
Old May 8, 2012 | 03:59 PM
dunno what happend, got fifth gear to work just fine and every other gear works as well, but now i lost reverse.....
Old May 8, 2012 | 07:54 PM
adjust cables. release cable clamps place shifter in 4th gear position ( tab is there for that, release shift lever clips and place in 4th gear tab position) secure cable clamps release shifter you are done.
Old May 9, 2012 | 03:33 PM
thank you for all your help
Old May 11, 2012 | 03:02 PM
ixxgh0stxxi's Avatar
powell ftw!!!!! good stuff sir
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
redlineblueline
Feb 7, 2008 03:27 PM
2K5SS/SC?
Feb 2, 2007 07:00 PM
