My DriveTrain Upgrade...
Well in about a month i will be getting a drivetrain upgrade including
CMfx400-6-puck
Fidanza Flywheel
Driveshaft Axles
installed for $2250.00
I was wondering, what mounts should i get for them to throw on in the mean time?
Thanks
CMfx400-6-puck
Fidanza Flywheel
Driveshaft Axles
Thanks
I have the ZZP engine and tranny mounts and both work very well in preventing wheel hop. Mine is practically gone actually. The only downside would be the vibrations, but I can live with that.
Originally Posted by CobaltBurst
you can get a 2.2 fidanza. Basically weighs less than the stock flywheel, = easier for the engine to turn = rpms dont fall as fast.
Originally Posted by wdsoccer
so it will work on a 2.2l auto? does it improve hp?
This has nothing to do with an auto. Automatics have a torque converter, manuals have a flywheel and clutch
since it is lighter it spins longer i believe it revs fast as hell i can tell u that i had one on my cavy....
There are in fact flywheels in automatic trans equipped cars. What do you think the torque converter attaches too? It is however a different flywheel. So to answer the question, NO, you can't use it on an auto.
The flywheel is a large disk mounted to the output side of the crankshaft that does 2 things. First, it gives you something to bolt your transmission to. Second, it provides rotational mass to keep the engine revolution speed smooth through the 4 stroke cycle.
