New clutch 101
Old Dec 20, 2009 | 11:13 PM
jthomas9's Avatar
New clutch 101
Hey guys and ladies, I need some help. I own a stock 2006 cobalt ss/sc and I think its time for a new clutch. It slips going into second and on shifts sometimes and even when i am using the cruise control it does not hold very well. So what do I do first? Is there an inspection I get or do I just go back to my dealer and tell them I want a new clutch.
P.S. This is the first manual trans car I have ever owned..just want to do it right.
Old Dec 20, 2009 | 11:16 PM
jsscooby's Avatar
First thing is I would avoid a dealer as their labor costs are going to be sky high. There are plenty of privately owned shops that will do a great job fro much less. Call one up after asking a few peoples opinions that have had service with them and have them check it out. They should be able to give you a definite answer if it is the clutch.
Old Dec 22, 2009 | 01:13 PM
NGASales's Avatar
Yeah i would first take to a private shop have them let you know if its the clutch 100% then i would look into an aftermarket clutch as it will be similar pricing but higher quality especially if you are planning on the modding the car
Old Dec 22, 2009 | 03:13 PM
roser4888's Avatar
I would recc replacing the flywheel and throw out bearing also while you are there
Old Dec 22, 2009 | 06:05 PM
DarkChild's Avatar
Exact year and problem I had. I am getting mine done right now at a dealership; cause I work there. Labor is cheaper than going to a privately owned garage and I trust a Gm certified mechanic 100% more than a normal Joe blow. Get your flywheel machined and also get the throw out bearing replaced. I just bought the bearing for $250... it is ridiculously excessively expensive. I pay $45 an hour whereas normally it would be $74 an hour. Keep in mind I am Canadian.
What sucked on mine was that the clutch disc had material left but wouldn't grip because the flywheel was heat soaked and so was the pressure plate.
Old Dec 22, 2009 | 08:32 PM
Sufu's Avatar
+1 on that ^
Replace the TOB now, or do the whole job over again because the TOB went out on you.
Old Dec 22, 2009 | 09:32 PM
Cefaln452's Avatar
TOB, and i have a stock disc in perfect condition if you would want that
Old Mar 11, 2010 | 06:19 PM
heartmycobalt's Avatar
^^^what he said
Old Mar 11, 2010 | 06:29 PM
doubledamageXX's Avatar
Dealership wanted almost 2,000 for my 05 ss Replacement. Find a place you can trust. I got mine done at my friends dads shop for 500+ the cost of clutch. Had it installed september last year and not a single problem.
Like everyone else has said... Machine the Flywheel at the very least, its better to just get a new one though.
Old Mar 11, 2010 | 06:33 PM
ViSiONZ's Avatar
Some good info to know. I'm about to replace mine as well.
Old Mar 11, 2010 | 07:43 PM
zrated89's Avatar
i just installed my G85 trans and added the GMP performance clutch which comes with the TOB as well. Got it for a great price on Crateenginedepot, Just past the break in period and this thing holds. Im also at a pretty good WHP level as well. For the price you cant go wrong
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
