No gears? Transmission help
Old Mar 8, 2010 | 10:09 PM
BNS06Mike's Avatar
I was driving down the road the other day w/o any problems.
Then i took the car out of gear and when i went to put it into the next, did not seem to have any vertical tension.
I can push the gear into the first position w/o engaging the clutch and slide it right across third and fifth.....while the car is running.
It will not engage into any gear.
Any one have this problem or have any ideas on what it may be?
I looked at the linkages under the shift knob and they are all connected and in tact.
i also moved the linkages on top of the transmission and both moved the shift knob.
Old Mar 8, 2010 | 10:23 PM
jonxxxedge1's Avatar
shifter linkage
Old Mar 8, 2010 | 10:40 PM
Nighthawk243's Avatar
Might be a busted roll pin or if you're really unlucky, the shift forks.
Try the roll pin first. It is the cheapest and easiest solution: https://www.cobaltss.net/forums/how-guide-43/how-fix-linkage-roll-pin-transmission-102830/
Old Mar 10, 2010 | 12:07 AM
KillinKrullin's Avatar
we already tore apart the console the linkage there is cool. we had two guys, one on the tranny moving the two (idk what to call them) things that attach to the linakge cables. moving those moved the cable in the console. one was springy the other wasnt.
i think we are going to do the roll pin. for startrs.... still looking for ideas.
Old Mar 10, 2010 | 08:18 PM
ok,
the roll pin was the issue!
thanks Nighthawk243!
Old Mar 12, 2010 | 12:47 PM
BNS06Mike's Avatar
roll pin is all fine and dandy thanks for the help Nighthawk243
and that walk through...good find and thanks for sharing it
P.S. KillinKrullin's car has no *****
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
