ottp stage 2 transmission mounts
hello all
I bought the ottp stage 2 tranmission mounts off a member here and the little triangle spacer for the front mount (i think ) was not included. My question is does anyone know how thick the spacer is and i can make a new one? or know anywhere i can get a new one.
Any help woiuld be appreciated
thank you
thank you
The Stage 2 Have 2 mounts and 4 round spacers and thats it, the stage one comes with the front mount two round spacers and one traingular spacer for the rear mount.
If you have the stage 2 foreal you wont need the traingular spacer..
For stage 1 the triangle spacer is for the rear stock mount and only comes with a new front mount(Plus the two round spacers). If you have the stage 2 you should have a new front and rear mount(Plus four round spacers) and don't need the triangle spacer.
If you didn't install the triangle spacer, the mounts are not doing you any good. Read the how to on it. If you have additional questions ask John Powell.
https://www.cobaltss.net/forums/driv...sj-lnf-253153/
