pop sound :(
Old Feb 18, 2012 | 04:36 PM
blackdew21's Avatar
Exclamation pop sound :(
I have a 06 ss/SC. While ago I'd get a pop sound from my front end. I'd only get it when I down shifted hard now I get it when I down shift or if the car jerks or if I'm on a hill and I reverse out of a hill. It's not loud but I can for sure hear it when the windows are down. Only thirexentng I have catless dp. Any help.would be awesome.
I didn't wanna make a new post so ill add it here.
Recently I've been having rpm problems. Every time I come to a stop my rp..s bounce. I came to a stop today at a red light and it bounced so bad it stalled and this isn't the first time it happened. Not to long ago I cleaned the mad. When it stalled and started back up my fuel gauge said it was on e but after turning it off and back on it went back to normal " was on a hill when it stalled" any help would be awesome.
Old Feb 18, 2012 | 04:44 PM
05Slowline's Avatar
Prob cv joint or something lol, i get it occasionally when i downshift and don't rev match, been doing it for 3 years haven't had an issue
Old Feb 18, 2012 | 05:28 PM
blackdew21's Avatar
Lol possibly! I get it I take off pretty fast. So u had have no problem?
Old Feb 19, 2012 | 11:02 PM
blackdew21's Avatar
Bump. Anymore ideas?
Old Feb 19, 2012 | 11:06 PM
05Slowline's Avatar
Nope no problem in like 3 years lol....clean your throttle body, probably what the bouncing idle is
Old Feb 19, 2012 | 11:46 PM
blackdew21's Avatar
Alright ill try that. Car almost has 70k on it and I do t believe it was cleaned before I got it.
Old Feb 19, 2012 | 11:49 PM
YelloEye's Avatar
Possible you destroyed a motor or transmission mount, unlikely but that fits the instances and sounds you're getting.
Old Feb 20, 2012 | 12:52 AM
blackdew21's Avatar
See thats what I'm thinking now. I've been having lot of movement from the motor.. jerks pretty good when Accelerating and letting off. Possible.
Old Feb 20, 2012 | 02:11 AM
YelloEye's Avatar
Pretty easy to check the front trans mount, rear one is under there a bit.
Old Feb 20, 2012 | 11:35 AM
blackdew21's Avatar
Well I had a Guy look at it and he said nothing looked wrong with them or feel wrong. But no one in the area realty has worked on a ss/SC. O5slowline said a Cv joint?
Old Feb 20, 2012 | 03:36 PM
YelloEye's Avatar
CV joint would be most noticeable in full lock, you can do that in an empty parking lot. Just find a spot you can do circles in, turn the wheel all the way left, drive forward at a slow pace keeping the wheel in lock, do the same all the way right, if you hear clicking your CV joints are shot. If not look elsewhere.
Old Feb 20, 2012 | 05:08 PM
blackdew21's Avatar
alright I'll try that. Could it be a control arm to?
Old Feb 21, 2012 | 01:14 PM
YelloEye's Avatar
Could be that, just think about when the noise happens and what could possibly be making that noise.
Old Mar 1, 2012 | 10:21 PM
shadowfaxss's Avatar
I have the same noise and had it on my 06 SS/SC as well. The noise never went away until the clutch was replaced. It is my opinion that the clutch pressure plate is watch causes thet noise you are hearing. Although I have the same noise and have had it in the past on both balts it has never caused an issue. I have the upgraded GMPP Clutch (about 30k on it) and just installed the ZZP mounts and ZZP axles so neither of those are an issue.
You will be fine.
Old Mar 5, 2012 | 01:30 AM
06 GM CobaltSS's Avatar
Check your sway bar links for play. Make sure that the bolts holding them to the bar are not loose. I had a similar problem and all I did was tighten the bolts using a 18mm open end and a 18mm deep socket.
Old Mar 30, 2012 | 09:05 AM
blackdew21's Avatar
Alright ill look at the links. I'm replacing the clutch and mounts with ottps.. this weekends. I guess it sounds like a ping pong ball hitting a table but little louder.. lol. Ive been hearing it a lot more lately.
Old Mar 30, 2012 | 12:27 PM
As you describe it....not the same sound I am hearing.
Old Mar 30, 2012 | 05:13 PM
SaberD's Avatar
you sure the sound isnt more of a click sound? this is a common problem with the axles. the fix is to either re-torque the axle nut or replace the axle.
Old Mar 31, 2012 | 11:42 AM
blackdew21's Avatar
I could be wrong with the sound. Guess ill replace them to and see how that goes.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
SlowSaturn
Sep 28, 2015 11:03 AM
