Problems with hurst short throw shifter! Help!
Old Jan 6, 2011 | 05:44 PM
kikal8's Avatar
ok.. so my brother decided to buy me a hurst short throw shifter for christmas. cool idea. anyways, we put it in last night and first of all he bought off a guy he works with at work and it was missing the snap ring that goes underneath the ball joint. so far that isnt causing any problems but its a matter of time. second, its all setup and in. the reverse lock works great and all the gears work perfect. the problem is 5th gear. first in no problem, second gear, perfect, third good, fourth good, and then you go to fifth. the way my stock shifter was, i push all the way to the right then straight up and that is fifth gear. with this shifter, i literally have to find fifth. its a pain in the ass. is this the way its supposed to be? not to mention this shifter isnt even that big of a difference from the stock shifter as far as throws. somebody please help. thank you..
KIKAL8
Old Jan 6, 2011 | 05:50 PM
Bl4des's Avatar
it is just not adjusted right
Old Jan 6, 2011 | 05:53 PM
RA040424's Avatar
... I did a search for "hurst 5th gear" there was pratically the same thread a week ago..
https://www.cobaltss.net/forums/driv...-throw-236769/
Old Jan 6, 2011 | 07:15 PM
kikal8's Avatar
thank you guys. very helpful. looks like i should have him return it. and no it isnt adjusted wrong, its supposed to be like that.
Old Jan 6, 2011 | 07:36 PM
Whining-devil's Avatar
i got rid of my hurst because i freaking hated fifth, got b&m and did not have this problem.
Old Jan 6, 2011 | 07:44 PM
thedude411's Avatar
U get used to it... Lol. Mines currently twists a bit. I'm going to have to drill out the one screw and rethread a higher quality one. Thats my only complain with the hurst.
Old Jan 6, 2011 | 08:56 PM
kikal8's Avatar
well lets hear everyones honest opinion. my brother has the oppertunity to bring it back and get a full refund. for people who have or have had it. would you take the deal?
and another thing. does anybody have ANY IDEA where i could find the stock shifter online? like the whole shifter.
Old Jan 6, 2011 | 09:26 PM
thedude411's Avatar
Well what'd he pay for it?
Old Jan 7, 2011 | 12:54 PM
slowbalt84's Avatar
crateenginedepot.com
Old Jan 8, 2011 | 08:08 PM
kikal8's Avatar
he said he only paid 80 for it which isnt bad but now he is offering to give it back and then give me 80 towards another shifter. im trying to stay under 200 dollars tho. does anybody have a good short throw shifter for under 200 dollars. and cratenginedepot.com has manual shifters but none of them have the reverse lockout.
Old Jan 11, 2011 | 04:31 PM
nevasuma's Avatar
I have the hurst. You do get used to the fifth gear problem but I still hate it. When I get some money I am going to change it out.
Old Jan 11, 2011 | 09:39 PM
kikal8's Avatar
ya. on thursday im gonna grab a twm. just trying to decide whether or not getting a different shift knob ohter than the aluminum one will be worth it.. dunno yet. but either way. new shifter soon =]
Old Jan 16, 2011 | 06:11 AM
coltsfan14's Avatar
well this thread made me not to get a hurst b&M it is
Old Jan 16, 2011 | 06:19 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
With all short shifters, it shortens the shift pattern. Stock fifth is all the way to the right, with the STS it's not quite as far. Which is what makes it a short shifter. after a couple days you get used to it and prefer it.
Old Jan 18, 2011 | 12:45 AM
Jkunzy1690's Avatar
incorrect.
OP, just spend some time adjusting it. its very picky, as any shifter. I would recommend the twm as there is no set screw like the hurst. Otherwise, fool around with the linkage and you will eventually get it right.
And since when in a short throw shifter are you short shifting into fifth gear?
Old Jan 18, 2011 | 12:49 AM
GM COBALT SC SS's Avatar
whats wrong with the fifth gear?? ive had this for about two years and never had any problems
edit: your shifter cables are not set in the right place. if you play with them a bit, you can get it perfect. in hindsight, i kinda remember that. my problem was getting the reverse lockout functional
Old Jan 27, 2011 | 05:38 AM
Stick's Avatar
I think I'm gonna go against my usual strategy, which is, "Pay cheap prices, get crappy equipment." and try out the Hurst, though it's not really cheap, it's the cheapest out of the 3 mentioned, at least that I have found, plus a better selection of knob, able to accommodate stock and aftermarket knobs
Old Feb 1, 2011 | 03:40 PM
Wangspeed's Avatar
I guarantee it's not adjusted properly. The reverse lockout is what determines your ability to find 5th and reverse. It's not just used for reverse. Just look at it and you can see this.
Old Feb 9, 2011 | 10:11 PM
Mr_Slobalt's Avatar
fifth is butter on mine....definitely adjust your cable
not the best shifter in the world but it does its job
Old Feb 14, 2011 | 04:11 PM
seeyaass's Avatar
Had this problem with 5th also, mess around with the cable clamp til you get it right.
Old Feb 14, 2011 | 10:19 PM
AyrtonSenna's Avatar
I have it, no problems at all. At the first time, it was, but then I've had it adjusted and it is great. Also a friend of mine has it on his, no problems for the 5th either.
Old Feb 15, 2011 | 04:20 AM
Stick's Avatar
Mine came in the mail last week.. Went to put install it a few days ago, got the stock shifter out and realized the Hurst was a few inches longer than stock.. Hurst shifter is getting sent back, and while the stock shifter was out, it got an inch 1/4 - inch 1/2 cut off, feels like a friends STS, with 0% of the price...
Old Feb 15, 2011 | 04:28 AM
07SSYellow's Avatar
Resident Post Whore/Troll
I have the TWM STS with upgraded cable clamp.and base bushings...it took me a day or 2 to get used to finding 5th its not all the way over and up its like 1/2" away from third...now that I got used to.it its butter...I got the stainless.knob too looks really good in the car...1" lower than stock and reduces throws by 33% and the upgraded cable clamp.is alot stronger than the stock plastic one and can take a beating....and the base bushings make for way smooth shifts too TWM FTW!!!
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
