question on auto tranny
Old May 8, 2005 | 06:50 PM
dnbguy86's Avatar
According to chevrolets website, the auto comes with a 3.63 axle drive ratio. Do all auto's come with this or is it an option only with the 1sb or lt trims or what ?
*MechanicalHEATER ENG MSRP*
Engine block heater (K05) $35.00
MERCHANDISED TRANS MSRP*
Transmission, 5-speed manual, includes 3.58 axle ratio (MM5) $0.00
Transmission, 4-speed automatic, electronically controlled with overdrive, includes 3.63 axle ratio (MX0) $850.00
* from chevrolets website
Old May 8, 2005 | 07:01 PM
tiny's Avatar
i think they all do
the manual has shorter gear ratios because it has more gears
Old May 8, 2005 | 09:48 PM
dnbguy86's Avatar
Originally Posted by tiny
i think they all do
You have a point, but thats pretty sporty gearing for just automatic sport compact.
Old May 12, 2005 | 08:16 PM
Yaj's Avatar
Yaj
Need to find out what the gear ratios in the transmissions are before you make any assumptions. If the auto has taller gears in it the final drive ratio may by higher in the auto even though the axle ratio is lower (lower gearing, numerically higher).
It might just have the slightly lower gearing in it because the auto is probably heavier...weight diff between manual/clutch vs. auto/converter - but that's just a guess.
Old May 26, 2005 | 06:15 PM
Maven's Avatar
Gearing : 4T45E:1st Gear Ratio 2.960:1, 2nd Gear Ratio 1.626:1, 3rd Gear Ratio 1.000:1, 4th Gear Ratio 0.681:1,
5spd manual in SS :1st 13/44, 2nd 25/44, 3rd 39/46, 4th 47/42, 5th 54/38(do your own math)
5sp manual in base/LS : 1st 3.58, 2nd 2.02, 3rd 1.35 , 4th .98, 5th .69
final effective drive ratios: 4T45:5.33 base 5sp:5.18 SS 5spd 5.76
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
