racing transmission
racing transmission
so the ss/sc and tc's use a racing transmission, just wondering if anyone knows how significant the difference in gear ratios are, from the standard getrag?
im wondering if its worthwhile to troll the junkyards and chance finding an sc racing tranny to drop in my car with new mounts.
2nd, It has taller gears than the F23 which IMO are already too long
3rd, the bolts to the flywheel are different, f23 has 6 f 35 has 8
4th, search is you friend
I'll confirm/elaborate some of what steddy said:
1) Not remotely close to a racing tranny. Actually, LOL, it was originially designed to be used for towing, hence why 1st gear is so short.
2) Personal preference, I don't mind the F35 gearing at all. It's a 2-gear road course car which makes for easy shifting.
3) Yes, you're looking at a TON of time, money, and headaches to make it work. You're better off sticking with what you have.
4) I concur.
4) I concur.
thx for the advice. All I know is that when I get a bit more power I wouldn't mind a racier tranny. Particularly with a wider 1st gear. The first gear and clutch In my car is like its for a beginner on stick. Did you know that you can not only let out the clutch w.o gas, but u can even start it in 1st w.o stalling! LOL
I know! Haha I found that out cause I had to try it cause my my cuz's cavy was the same! And I found out u can start it in gear cause my Balt was shipped with a faulty clutch which delaminated on the highway LOL. Took me a minute to find out I had no clutch, but before that I tryes starting it again with the clutch pedal in while in first, the engine stsaryed and I started rolling! Haha ever since then, I've learned to drive without a clutch just in case! LOL
Im getting a race tranny for mine....yes, its still a 4T45-E GM FWD Auto tranny.....but its a race tranny for the little goodies done to it.
not true i accidentally started it in first gear and it stalled...especially with reverse (the stalling sounds nastier too >_<) and you cant start the car without the clutch in anyway
hmm i gotta test that out
no i was in a parking lot. the car stalls if you dump the clutch in first. (no need to go slow if your in or going into neutral) if you want it to start going without stalling you gotta be really slow on the clutch till it fully engages. but only on level ground. hills you need to tap the gas a little
