Rear Axle Replacement - need some assistance
I have a 2007 Cobalt LT with the 2.2, 4 lug axle. I am not sure if it has ABS and not sure how to find out. Aside from determining which axle to purchase, is there a How To to actually remove and replace one? I have tried to find one, but I can't seem to make any sense on how the forum is organized.
Thanks
Robert
Thanks
Robert
Blasirl (11-19-2018)
Easiest way to find out if you have ABS: Look for a connector/wire coming from the wheel bearing. If you have that, you have ABS.
I can't tell with the pictures, but that positive camber on your tire I would check to see if the beam is cracked. If so, you need a replacement:
Axle Assembly - GM (15232752)
https://www.gmpartsdirect.com/oem-pa...w0LWdhcw%3D%3D
Or do some junkyard digging.
The part number is the same for all models, including SS, so I would say they are interchangeable.
The back of these things are stupid easy. I would replace all of these parts: the rear beam axel you can get from a junkyard obviously from a cobalt/g5 that does not have rear end damage.
I would buy the wheel bearings/drums new -> https://www.rockauto.com/en/catalog/chevrolet,2007,cobalt,2.2l+l4,1433735,brake+&+whee l+hub,drum,1744, and;
and 2 new shocks -> https://www.rockauto.com/en/catalog/...+absorber,7556
If you can get the rear beam cheap from a junkyard (ALWAYS NEGOTIATE), the other parts would only cost ~$100-$150.
Remember, anything with brakes/suspension, you need to change out in pairs.
Blasirl (11-20-2018)
This what I removed and replaced with my junkyard axle. I had to get new springs - wish I new sooner, I would have gotten Eibachs!
This is where the impact occurred
My daughter spun out in the snow and BAM
This is the axle I removed
This is a closeup of the bend
I wish I knew the springs broke. You can tell they rotted away at the breaks
