Reverse Switch
Old Nov 30, 2008 | 05:25 PM
T Dawg's Avatar
Reverse Switch
Yes I have looked all over before posting and I only find hazy mentions and opinions, but I need to know where the reverse switch is located. My reverse lights went from working sometimes to never. Good bulbs. I used to be able to kick it in and out of reverse a couple times and they would come on. Now I have nothing. 05 5 speed 2.2L. Any help is appreciated.
Old Nov 30, 2008 | 05:38 PM
originaladrian's Avatar
check ur fuses home fry
Old Nov 30, 2008 | 05:47 PM
T Dawg's Avatar
Sorry, I guess I forgot to put that in the original post. Good bulbs and fuses all around. Yes the car is running and in reverse.
Old Nov 30, 2008 | 05:49 PM
alright just making sure, u would be surprised at the number of people who post on here first without even doing things like checking there fuses if its electrical our scanning a code if they have a CEL.
Old Nov 30, 2008 | 05:51 PM
dsp86's Avatar
all i can tell by what i see on SI. its on the left side of the trans. says to remove the LF wheel. id say go buy one then take off ur wheel and look for it should look just like the new one. pretty easy to install
Old Nov 30, 2008 | 06:00 PM
T Dawg's Avatar
From what I have read on other threads and what I can see, the only thing close there is the speed sensor.
Old Nov 30, 2008 | 06:45 PM
qwikredline's Avatar
make sure the reverse switch if plugged in its on the top of the trans near the shifter if you have worked on your car you may have forgotten to plug it in
Old Nov 30, 2008 | 09:41 PM
T Dawg's Avatar
I've only done oil changes etc, nothing fun. A pic of the actual switch would be great.
Old Dec 1, 2008 | 04:42 PM
FloDamien07's Avatar
we had that problem before it burned out completly and we had to take it in to the shop..I know that it is located under the fuse box under the hood and the whole thing has to come out to get to it..
Old Dec 2, 2008 | 11:49 AM
T Dawg's Avatar
That's what I was afraid of. I was just confirming my suspicions before tearing out the fuse block.
Old Dec 2, 2008 | 04:05 PM
Good luck to u on that...but it isn't a fuse it is the whole reverse switch that has to come out
Old Dec 3, 2008 | 07:13 PM
dsp86's Avatar
the reverse switch is only on the top of the tranny in the supercharged cobalt. if u have an lt or something its on the side. atleast thats what GM SI2000 says.
Old Jan 19, 2009 | 11:32 AM
T Dawg's Avatar
I finally figured it out. The switch is fine, but whatever pushes against the switch is not engaging it. yay. At least I am back to sporadic rather than nothing.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
royce777
Sep 28, 2015 07:11 AM
ashalle2
Sep 16, 2015 10:36 PM
TrevorB
Sep 14, 2015 03:59 PM
