Shifter adjustment?
Old Nov 14, 2008 | 06:05 PM
Sergio's Avatar
Shifter adjustment?
Recently my car has started to block me from going into third or fourth. This happens rarely (about once per drive). I have to go back to neutral and then it goes in just fine. This is when I'm driving calmly through town, no fast shifting at all.
Any ideas? Could it be my shifter cables need some adjustment and if so, how is that done?
Thanks
Old Nov 16, 2008 | 06:35 AM
chevy cobalt 08's Avatar
Put the shifter in neutral. Then pull this clip up with a screw driver so it loosens from the cable. It pops up only an inch, it doesn't fully come off so make sure that doesn't happen! Then adjust the shifter (it should move back n forth freely without the cable it self moving) till the shifter sits straight. You can use a bubble leveler to see if it's straight if you want. Then push the clip back down to lock it. If this don't help, then you have a syncro issue. Take it to the dealer.
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
Cptnslo
Sep 24, 2015 09:32 AM
The Rookie24
Sep 20, 2015 04:33 PM
