Shifter starting to feel more notchy
Old Sep 23, 2011 | 09:22 PM
SSean's Avatar
Shifting
A fluid change will help with shifting. Changed mine at 23k miles and I am happier now. Also found quite a bit of metal shavings on magetic drain plug. 75w85 or 75w90 GL-4 gear oil is what you need, 2 quarts.
Old Sep 23, 2011 | 10:11 PM
Dart_SI's Avatar
Is it simple to do? I may do it this weekend
Old Sep 24, 2011 | 02:29 PM
Gelladuga69's Avatar
It's easy. I did it maybe 3 weeks back.
Just two plugs for drain and fill.
I actually followed a guide on here somewhere.
I also had some shavings when I changed mine and my oil was pretty dark.
Used 75w-90 gl-4 without all the additives.
Old Sep 24, 2011 | 03:05 PM
Dart_SI's Avatar
can you get the gear oil from an auto parts store like napa?
and thats the oem fluid too right?
Old Sep 24, 2011 | 05:54 PM
SSean's Avatar
The only brands I saw available in stores are the Royal Purple 75w90 and Lucas 75w90 synthetic gear oil which are rated GL-4. The stock is 75w85 Castrol Burmah. The dealer may not have it or will have to special order the fluid and it would be much more expensive. I ended up using the Lucas gear oil. A closer match to stock would be the redline mt-85, but you will probably have to order this online.
Old Sep 25, 2011 | 10:34 AM
Yes, you can, but not the OEM fluid.
The OEM fluid is about $20-25/quart from the dealership and you need 2..
Manual Transmission Fluid SAE 75W-85 GL/4 88862472 - Crate Engine Depot - PN and info.
I used Castrol, but it wasn't Burmah.
Old Oct 1, 2011 | 10:10 AM
x_sgs_x's Avatar
Yea I have the same problem. Ive noticed that if I throw it in neutral and rev it a bit , it shifts a lot better. So im thinking the fluid needs changed too but i had an axle seal replaced a few months back and I would think that means they would have had to at least add some fluid but who knows lol.
Old Oct 2, 2011 | 08:43 PM
xxxxsh4d0wxxxx's Avatar
https://www.cobaltss.net/forums/driv...thread-230048/
Old Oct 2, 2011 | 09:05 PM
gotboost?17's Avatar
Nothin Stock
mine seems different time 2 time too
Old Oct 7, 2011 | 05:54 PM
Dart_SI's Avatar
update: so far fiddling with the linkage works, but the problem comes up every now and then. still havent changed tranny fluid.
as far as shifter sloppynes, i gotta try to change the roll pin. i may try changing my whole shifter tho, as ive noticed there seems to be some play in a certain part that may not have anything to do with the roll pins.
Old Oct 7, 2011 | 05:56 PM
  #36
DBlock's Avatar
QUEEF-NUGGETS
Mine just started doing it after i put in my new clutch.
Old Oct 7, 2011 | 05:57 PM
  #37
Dart_SI's Avatar
where this part connects seems to be a lot of play. i dont know if its normal or not, but maybe a short shifter or another stocker would help.
Old Oct 7, 2011 | 05:58 PM
  #38
DBlock's Avatar
QUEEF-NUGGETS
Im going to adjust my linkage this weekend..cause mine gets annoying,feels so rough haha
Old Oct 7, 2011 | 05:59 PM
  #39
Dart_SI's Avatar
the roughness and how much play i have bothers me. i like my shifters nice and tight. lol
Old Oct 7, 2011 | 06:01 PM
  #40
DBlock's Avatar
QUEEF-NUGGETS
same here...mine got worse after the new clutch went in,so idk what could have happen.
Old Oct 7, 2011 | 11:01 PM
  #41
AndrewSS/TC's Avatar
Put a ziptie around the two cables you can see when you pop the cup holder out, it gets rid of a lot of slop. Ghetto, but worked for me.
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
