Shifting Issue
Shifting Issue
Well, my problem is when im in 3th gear and i want to shift the 4th gear around 5900 rpm or higher i can't engage the next gear because it's make a kind of wall that don't allow me to pass the 4th gear ,but if i hit the cut off in 1-2-3 for example it doesn't make it, but only on 4th gear and i don't know for the 5th gear because once the 4th is block i can't pass any gear until i slow down.
So what can be my problem. master cylinder?
LSJ? Slave cylinder (throw out bearing as'sy) getting weak would be my guess. Not disengaging the clutch far enough.
LNF? Aftermarket clutch that needs the ZZP adjustable rod.
bent clutch rod? u can look by ur clutch pedal to see if it looks straight or bent....if bent replace with this. get the master cylinder as well dont be cheap! when did a pull threw first to 2nd, 2nd wouldnt let engage. so i bought this and it shifts good now. my rod wasnt bent but i dont think the clutch was engaged all the way. something to check into
Cobalt & Ion ---> ZZ Performance
