Shifting Issue
Old Sep 26, 2010 | 06:42 PM
frankqc's Avatar
Shifting Issue
Well, my problem is when im in 3th gear and i want to shift the 4th gear around 5900 rpm or higher i can't engage the next gear because it's make a kind of wall that don't allow me to pass the 4th gear ,but if i hit the cut off in 1-2-3 for example it doesn't make it, but only on 4th gear and i don't know for the 5th gear because once the 4th is block i can't pass any gear until i slow down.
So what can be my problem. master cylinder?
Old Sep 26, 2010 | 08:18 PM
Iam Broke's Avatar
LSJ? Slave cylinder (throw out bearing as'sy) getting weak would be my guess. Not disengaging the clutch far enough.
LNF? Aftermarket clutch that needs the ZZP adjustable rod.
Old Sep 26, 2010 | 08:21 PM
frankqc's Avatar
yeah sorry i forgot to say that i have an LSJ
Thanks
Old Oct 1, 2010 | 12:32 PM
BLUE TRANSFORMER's Avatar
I have the same problem this started to happen after I installed the OTTP stage 2 kit.
sub'd for more info.. I am currently on the stock clutch set up..
Old Oct 1, 2010 | 12:40 PM
scotch89's Avatar
bent clutch rod? u can look by ur clutch pedal to see if it looks straight or bent....if bent replace with this. get the master cylinder as well dont be cheap! when did a pull threw first to 2nd, 2nd wouldnt let engage. so i bought this and it shifts good now. my rod wasnt bent but i dont think the clutch was engaged all the way. something to check into
Cobalt & Ion ---> ZZ Performance
Old Oct 1, 2010 | 07:03 PM
frankqc's Avatar
i'm sure it's not the rod because i have the stock clutch and samething for blue.
Me i think it's the master cylinder or the throwout bearing of the clutch
RaginChopsuey
Oct 27, 2015 01:27 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
2009blackSS
Sep 30, 2015 05:57 PM
yellow dragon
Sep 28, 2015 09:49 PM
