Snap ring on right side axle?
Old Sep 18, 2007 | 09:47 PM
Blown 4-banger's Avatar
Angry Snap ring on right side axle?
WHAT THE ****!!?!?!? I sold my axles to Hatrickstu, but before I could ship them I have to get the right side axle disconnected from the black shaft that comes out the back of the transmission. Theres a ******* huge stupidly thick snap right holding the axle to the shaft. I went out and spent $25 on a pair of snap ring pliers and they open the ring, but theres no room for the ring to expand, so it just opens a tiny little bit and then slips off the pliers. HOW THE **** DO YOU GET THAT LITTLE **** OFF THERE!?!?! I SWEAR I'M GOING TO CUT THE ******* SHAFT!!!!
Thats the ******* clip that makes me want to kill something!!!
Old Sep 18, 2007 | 09:53 PM
06blackg85ss's Avatar
I never took that off when I pulled my axles man... just use a flat prybar to break em loose at that bearing where they come together.
Old Sep 18, 2007 | 09:59 PM
hatrickstu's Avatar
see i told you bro, rip that bitch out!
Old Sep 18, 2007 | 10:10 PM
c24na's Avatar
it will just slip out. Lubricate it with wd40, let it sit for bit and it will slide out if you hit it with a mallet (no need to take snap ring out).. I went through that too, the first time i tried to take the axle out of the 1/2 shaft thingny.
Hope that helps.
Nate
Old Sep 19, 2007 | 02:21 AM
2K5SS/SC?'s Avatar
A pry bar works wonders man. Jiggle it around a bit, wedge a prybar behind the big thick part of the axle and pop her out. Easy day.
Old Sep 19, 2007 | 02:30 AM
KillerBee's Avatar
Wow did not think that those would be that hard i aint gunna do mine if i get a set no way in h e double hockey stick
Old Sep 19, 2007 | 08:11 PM
See, son of a bitch! I tried using a pry bar when I was blind with rage yesterday, but my dad stopped me and said I would break it. I shouldn't have listened to him I'm gonna go use my biggest pry bar and rip that mother ****** out!!! Then melt it down... wait, no I won't melt it. I'll send it to Hatrickstu.
You guys were right! I just blasted it with WD-40, then smacked it with a rubber mallet a few times, and it popped right out. Thanks guys
Last edited by Blown 4-banger; Sep 19, 2007 at 08:11 PM. Reason: Automerged Doublepost
Old Sep 19, 2007 | 08:17 PM
stryder's Avatar
now hit the easy button
Old Sep 19, 2007 | 08:22 PM
hatrickstu's Avatar
he really was enraged, like furious haha
Old Sep 19, 2007 | 11:55 PM
c24na's Avatar
No problem dude. What I don't get, is that gm never put any lube/anti seize in there . Imagine, if you go to pull that about in another couple of years for the first time. It will be corroded togethere
Nate
biniecki
Oct 25, 2015 02:23 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
