Sounds like a coffee grinder
Old Jan 9, 2011 | 11:15 PM
05RLS2's Avatar
I am posting this up to see if any other LSJ SS cars are having the same things go on as me. Has anyone else here experienced a grinding or rattling noise coming from the transmission if their car has sat outside during cold temperatures (30 degrees or less)? It sounds like a coffee grinder when idling the first few minutes, then goes away. It doesn't do this if the car is started after sitting in the garage or in warmer temps, or any other time of the year. I know for a fact that is not coming from the SC, becuase the noise goes away when the clucth is pressed in. It almost seems to be something with the throw out bearing, but it seems odd that the noise only happens when the car is in cold temperatures. If it was faulty it seems as if it should be making a noise at any temperature. Is this just a cold temperature thing related with these cars?
Old Jan 16, 2011 | 06:12 AM
coltsfan14's Avatar
ur clutch could be going bad
Old Jan 23, 2011 | 01:46 PM
xxxxsh4d0wxxxx's Avatar
Mine does the same. Clutch out, it makes the noise, clutch in, it stops. Only since winter.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
