Spec 3+ Clutch and... what flywheel works best with it?
I'm looking for some input around those that have done swaps with Spec clutches. I've had a Spec 3+ I've been saving for some time now. My question is what flywheel have people been having the best luck with pairing it with? GM/stock or a Spec perhaps?
I seem to remember hearing something about the holes not quite being right with the GM one. I also seem to remember that it tended to chatter with the Spec flywheel.
Just looking for some clarity here. Thanks in advance!
i wouldnt recommend the stock flywheel for the spec stage 3+. i have a theory to all the said failures being had on here. i specs aluminum flywheel.
i have personally run a stage 3+ on 2 different big turbo setups with easily over 80+ dyno passes on it and i pulled the clutch out today because my car totaled and i wanted my parts and theres PLENTY of life after all the abuse.
Yep usually if they offer an upgraded flywheel I always recommend it to customers as they are usually ment to pair up. The light replacement clutches like the stage 2 might be ok wjth an oem flywheel
