stock flywheel tq specs?
Old Sep 23, 2008 | 11:56 AM
burntorange's Avatar
anyone know the factory flywheel's tq specs? thanks!
MIke
anyone? The book doesn't say and I have called the stupid dealership and both parts and service say that they don't have access to that information.
Last edited by burntorange; Sep 23, 2008 at 11:56 AM. Reason: Automerged Doublepost
Old Sep 23, 2008 | 12:30 PM
Pickles's Avatar
Here is the paragraph from the ecotec clutch book:
With the replaced flywheel torqued to 39 ft-lb
(53 N-m) on the crankshaft and each bolt rotated
another 25 degrees
, it’s now time to install
the new clutch on the engine. Start by positioning
the clutch on the three small pins at the
outer edge of the flywheel. Then, finger start all
the bolts in their threaded holes.
Old Sep 23, 2008 | 10:11 PM
qwikredline's Avatar
another 25 degrees
right here you go: flywheel: enter the screws so the flywheel is snug against the
crank flange and then tighten in two steps cross wise;
screw nr. 1, 5, 2, 6, 3, 7,4, 8
to 53 Nm and then 25 degrees. you need to buy the proper angle torque tool to do the job right all the best
Old Sep 26, 2008 | 04:02 PM
it helped out a ton and the job is done! Thanks everyone!!!!
MIke
Old Oct 20, 2015 | 03:34 PM
Barkleyj605's Avatar
Is this 2.2 or 2.0 I have the 2.4 and they interchange just not the 2.0
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
