Symptoms for cracked flywheel?
Old Oct 10, 2012 | 06:12 PM
seeyaass's Avatar
Anyone know the Symptoms for cracked flywheel? Getting a real bad wobble when I'm drivin.. It's all different times to.. Could be wot.. Uphill under load.. Flat road just cruisin.. Then sometimes it won't wobble.. Feel it a little in the steering.. Having trouble diagnosing it.. Was thinking something to do with flywheel or trans, but what are the symptoms of a cracked flywheel?
Old Oct 10, 2012 | 07:08 PM
emiller's Avatar
Flywheel is rotating whenever the engine is on. If your problem is only while moving I'd think its the trans or something else.
Old Oct 10, 2012 | 07:12 PM
seeyaass's Avatar
Okay cool, what about cllutch? Anything involving the clutch could do that? And the trans?.. What in the trans could make a bad wobble?
Old Oct 10, 2012 | 08:44 PM
rwperlaki's Avatar
Sounds like the diff in your trans my car did the same thing when my diff was going bad
Old Oct 10, 2012 | 10:02 PM
seeyaass's Avatar
Was there any way to diagnose it? It's did it before very slightly though. This is a new zzp stage 1 trans in there now..
Old Oct 11, 2012 | 11:43 PM
rwperlaki's Avatar
Get under the car and shake the axles up and down back and forth and check end clearances in the diff
Old Oct 12, 2012 | 10:50 AM
seeyaass's Avatar
Okay I'll do that .
DANRICKARD
Oct 1, 2015 12:08 AM
jas09ss
Sep 26, 2015 01:06 PM
ashalle2
Sep 17, 2015 04:58 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
