Synthetic trans oil
Old Feb 19, 2006 | 10:57 AM
avro206's Avatar
Synthetic trans oil
Just wondering if anyone has swithced to synthetic transmission fluid. Tell me about your findings/results.
Stuff seems pretty cheap but then the labor at the shop will be a little more I guess
Old Feb 19, 2006 | 11:06 AM
Chevypowered's Avatar
I would also like to know what the best transmission oil is for a manual, i'm goig to change mine out when i get mine worked on.
Old Feb 19, 2006 | 06:38 PM
JapEatr's Avatar
South Central *********
the factory fill is synthetic gear lube 90W
Old Feb 19, 2006 | 06:54 PM
Malaclypse's Avatar
First, the manual transmissions in our cars use ATF, not straight weight gear oil. Second I doubt its synthetic for the 2.2 and 2.4 manual trannies. When I replaced mine it felt and looked just like good ole Dexron III. Its possible that GM gave the 2.0 SC synth trans fluid from the factory.
Old Feb 19, 2006 | 07:25 PM
avro206's Avatar
the 2.2L/2.4L Getrag use ATF Dexron 3.
The 2.0 S/C Saab trans uses gear oil
Old Aug 7, 2008 | 09:08 PM
jerrodmann's Avatar
So I guess I don't need to change out any fluids in my transmission because of the gear lube?
Old Aug 7, 2008 | 09:34 PM
rollingboostedss's Avatar
in 2006 GM changed everything to AF6 In there auto trans which is a syn based fluid. now in that Manual it is a syn based fluid which is like a 75-90w I used the BG snycroshift which is like the autotrac that GM puts in there transfer case for there truck.
Old May 22, 2010 | 04:20 PM
cfdp's Avatar
I have an 05 w/ an auto trans. Do I have to stick with reg Dex III, or can I switch to synthetic?
Old May 22, 2010 | 07:37 PM
how many miles is on it? sometimes switching to synthetic with high miles may cause issues.
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
