Tranny question NEED HELP
yeah man, first one I did took me about 8 hours on jackstands, and hand tools. I bet with a lift and air tools both of us could knock it out in under 4.
as for the bully clutches, unfortunately you have to use the 4 puck one, the six puck is too heavy a disk and won't release at higher rpms.
this one was also one of the first, and for reasons not really worth mentioning is just collecting dust at my friends place
hmmm i better look into that!
Last edited by hatrickstu; Apr 25, 2008 at 11:21 AM. Reason: Automerged Doublepost
Stu... when you are dropping the Tranny... and reading those instructions.
There is only ONE bolt behind the Starter that needs to come out... not two. I spent an hour looking for that second bolt, that GM said was there.
GL with the tranny drop
i did mine in about 9 hours messin around not workin on it the whole time...but it still takes a good amount of time
with a lift / air tools it can be done in under 3 hours by 1 person(if they know what their doing and have all the tools) im hoping to get a hold of a lift to drop my trans again
but anyway, good luck, and i hope you have the time on your hands to do this...
ALSO if you haven't already, replace the throwout bearing...never hurts to do it, especially if your throwing in a new clutch(this is why i have to drop my trans again, mine is going bad, it squeaks very loud)
thanks for all this info guys. i havent decided if im going to do it or have someone do it yet. the tranny came with a throw out bearing so i might just leave it in there (only has 5K miles on it)
Basicallly without being specific ...if u need a desription beyond this I dont thinnk u should be doing it .
-support engine . I used a hoist because with a sliding rail with hooks and attached that to the engines assemble line hooks ....its all I had . Last time I had the adjustable GM frame rail tool .
--Remove CAI ( dont have too , the xtra room is nice though )
-remove fuse box
-tied up all the wiring , take off ABS module connector so u can move the harness it attached to completely outa the way
-remove the shifter cables and 2 connectors from trans
-remove starter and ic pump tied it up outa the way then remove bracket
-Remove wheels
-remove tie rod ends
-remove slider bolt from ball joints
-remove steering rack and sway bar bolts
-remove fender splash guards ) u need to to get to the front cradle bolts .
-remove 4 21 mm cradle bolts and drop cradle
-remove all trans mounts
-remove axles . People have their prefereces here . It was easy and qwik for me just to take the brakes completely off , then unbolt the steering knuckes and pull the axles out with the knuckes attached . If I was on a lift like last time I would I woulda left the knuckes attached as theres enuff play in the shock assembley o pull them out and tie the ends up outa the way . I was on the floor so I wanted all the room I could get .
-remove the remaining drivers side trans mount bolts on the frame rail .
-then lower the engine a bit so the driverside hangs down
-support the trans and remove all bolts . I was alone without a trans jack . this trans is shaped like frikin vert ramp so u gotta get creative
- separate trans and motor , I lowered and pull the trans out the wheel well
Do your clutch , then reverse the process . Make sure u have 10 mm reverse star socket for the clutch . If i didnt have an impact I would beat my head in with a sledge
Stu - the TB should be fine with only 5K miles . Just make sure it move freely . My warranty trans the TB was sticky and not smooth feeling when u manually compressed and released it and it only had a few thousand miles ....I had one in the shop with 10K miles I replaced it with that moved freely and smoothly like it should .
It isnt thaaaaat bad . I got stuck doing mine alone couple weeks ago
-remove fuse box
-Remove wheels
I ended up taking the padded seat off my stool and set it on the jack pad on the jack . It was enuff cusion the trans sank in and didnt fall off .
....just warning for those wwith only hand tools . Make sure u have snchromesh to refill the trans with as some will come out when u remove the axles . Also when I put the shifter cables back on the trans , I put some grease on the ball fittings on the forks , it made my shifter feel a little smoother operating .
-remove fuse box
-Remove wheels
...and I did
Last edited by SilverSS/SC; Apr 26, 2008 at 08:57 PM. Reason: Automerged Doublepost
well here is an easy way to tell if your bearing is good, ill show you my old one and my new one and point out the what to look for, brb in a min with pics
on the left is a new one, right my old one where you need to look as at the end area, the gap on the bearing on the right is no good, you can actually play around with it and move it from looking like the gap on the left then to the lookin like the one on the right, kinda hard to explain, since i can pick apart a throwout bearing
just something to look for and check, the bearing should have absolutely no play in it
Iceberg
Sep 29, 2015 12:33 PM
