Trans different ?
Old Aug 28, 2009 | 02:09 PM
crazysteve's Avatar
Trans different ?
Does any one know if the TC and SC trans are the same and if different do you know the gearing change.
Thanks in advance.
Old Aug 28, 2009 | 02:48 PM
Smus's Avatar
Per Wikipeida
Both cars use an F35 Saab Transmission...
http://en.wikipedia.org/wiki/F35_(MU3)_transmission
I believe the ratio is the same, but dont quote me on that.
Old Aug 28, 2009 | 02:50 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yes the TC transmission has a little longer gearing than the SC, but both will physically fit
Staged07SS's Avatar
Administrator
Administrator
they use the same trans, but have diff gearing. the ss/sc has 4.05's & the ss/tc has 3.82's.
Old Aug 28, 2009 | 07:22 PM
crazysteve's Avatar
I know they are f35's mostly was wondering about gearing the cobalt tc and hhr ss have almost completely different gearing just wonder if the final is the only difference
Old Aug 30, 2009 | 11:02 PM
qwikredline's Avatar
see post above your last
Old Sep 7, 2009 | 01:47 AM
fakameanrepresent's Avatar
oooo, so if i slap a S/C on my T/C=better 1/4 miles times?
Old Sep 7, 2009 | 06:16 AM
HunterKiller89's Avatar
...im pretty sure they both use the 3.82 final F35....they should have identical gearing
but yes, exact same transmission, different final drives.
Old Sep 7, 2009 | 06:30 AM
steddy2112's Avatar
Nope.
The HHR SS's have the 4.05 F35.
Old Sep 7, 2009 | 12:28 PM
Sharkey's Avatar
more than likely it would be slower. 1st gear is so incredibly short in an ss/sc once its up around 250hp, all you end up doing is spinning.
Old Sep 16, 2009 | 01:01 AM
mikedotrudolph's Avatar
Question about an ss/tc transmission, more apposed to the shifter, what would it take to slap a 09 ss/tc shifter onto a 09 lt
Old Sep 17, 2009 | 09:37 AM
4.45 would be better still thats what I run. short gears =faster elapsed time= win. penalty is noise from final drive gears, first is still short (er)
Old Sep 17, 2009 | 01:09 PM
Ryan@zzp's Avatar
The LNF has a 3.82 final drive and the LSJ has 4.05 final drive, 1,2,3,4, have the same ratio the final drive is the only dif.
Old Sep 17, 2009 | 01:19 PM
steddy2112's Avatar
No, the COBALT SS has the 3.82 final drive, the HHR SS has the 4.05
Old Sep 17, 2009 | 02:19 PM
No one knows what it would take to put the ss short throw onto a lt
Old Sep 17, 2009 | 04:12 PM
Ryan@zzp's Avatar
I just had an LNF tranny and two LSJ trannys apart yesterday and the LNF ID tag has the 3.82 final and the LSJ ID tag has the 4.05
LNF being SS/TC.
Old Sep 17, 2009 | 04:24 PM
steddy2112's Avatar
LNF comes in an HHR SS as well and has a 4.05 final drive F35 just like the SS/SC
And for the record I know the LNF Cobalt comes with a 3.82 final drive:
I was making sure people understood that the LNF HHR comes with a 4.05 in their F35 set up.
Old Sep 17, 2009 | 05:26 PM
Ryan@zzp's Avatar
You are just saying that there are both options for the HHR or the LNF HHR has only a 4.05 final, either way the gears are the same the final drive is the only dif. So the HHR has the same setup as a LSJ. The trannys swap LNF to LSJ or LSJ to LNF without any changes.
Old Sep 17, 2009 | 05:31 PM
spike's Avatar
You are just saying that there are both options for the HHR or the LNF HHR has only a 4.05 final, either way the gear are the same the final drive is the only dif. So the HHR has the same setup as a LSJ. The trannys swap LNF to LSJ or LSJ to LNF without any changes.
that would be fun!!
Old Sep 17, 2009 | 08:21 PM
Originally Posted by spike
that would be fun!!
what would exactly?
Old Sep 17, 2009 | 10:55 PM
spike's Avatar
what would exactly?
LNF trans in lsj car imo
Jan 12, 2016 12:01 AM
TurboTechRacing
Oct 27, 2015 07:58 AM
Sep 27, 2015 08:53 PM
zdohare
Sep 23, 2015 11:31 AM
